Haul Out Schedule
carl
Haul Out Schedule
Post by carl »
Re: Haul Out Schedule
Marysville Marine is were I got my non metallic cutless bearings. You just have to know the exact sizes. There is also cutless bearings in the rudder tubes, usually you have to cut the bearings in half and put one in the top side and one in the bottom.
carl
Post by carl »
Carl,
Full length bearings aren't needed. The supporting points are more than adequate. Additionally, when it comes time to change them (in several years), you'd find it very tuff to remove.
NOTE - FastJeff had a process on an old site that used a reverse ground "V" chisel to remove old bearings.
carl
Post by carl »
Post by Maestro »
I purchased my non-metallic bearings from this place:
https://www.deepblueyachtsupply.com/marine-bearings
Worked out great!
After reading that list, boy am I glad to be a trailered, 19 foot I/O guy!
