Valve cover gasket 440 300hp.
martindesign
Post by martindesign »
Stupid question, I need to do valve cover gaskets on my 440s. They are the old style 1969 to be exact. Any idea if I can slip them out without pulling the manifolds? It looked like I could but I only quickly glanced at it when I noticed one was sleeping a bit.
Catawba Oh
spdracer
Re: Valve cover gasket 440 300hp.
Post by spdracer »
Should be able to. A 1/4" drive 7/16" swivel socket with make this job much easier.
Chris Hamann
Lakeland Auto & Marine
Port Clinton, Ohio
martindesign
Check. Thank you. Wasn't sure if the lip would fit out between the manifold and the rockers.
Catawba Oh
Before removing them, try gently re-tightening the bolts. The gaskets relax over time and the bolts get loose.
martindesign
They're cork, over tightening cork gaskets distorts stamped covers and will make it leak worse. Im gonna replace with a better rubber gasket. Thanks though.
Catawba Oh
Beat them with a ball peen hammer too.--Ed
What he means is, turn the cover over and knock the distorted areas about the bolt holes flat with a ball peen hammer.
martindesign
Or beat the heads with the hammer to pop the gaskets loose.
Catawba Oh
Rubber hammer to get parts loose, ball peen to reverse the dimple that forms on a sheet metal valve cover. No oil pressure on these valve covers so it doesn't take much to keep the oil in. If they leak you have a very poor seal.
And the biggest hammer you have when you give up.
