Window track channel
jmonday
Post by jmonday »
Does anyone have a lead on the three groove window track in plastic or aluminum?
Jeff Monday (Blue Mondays)
Lower River rd
Rabbit Hash KY
Verboatn
Re: Window track channel
Post by Verboatn »
I have some pieces of the plastic channel. How much do you need?
Verboatn - Werner Wildenburg
32' Express 1977 w/ twin 318s & 1:1 Velvet Drives
jmonday
Post by jmonday »
Im helping with a houseboat and my express so I can not find it anywhere so I'm tooling it up now should have it in a few weeks but thanks. Both of ours in plastic but I'm thinking of doing aluminum with the poly glide I have a supplier for that just need the correct thickness.
Lower River rd
Rabbit Hash KY
For long term use, aluminum is the better choice. Don't forget to make sure you have sufficient drain holes at the exterior ends of the channels to prevent water from running back into the cabin. John Althouse used to have lots of the polyglide in the correct width - don't know who stocks it
The plastic works, too. but it will eventually disintegrate from sun rays and will have to be replaced. It's cheap, so buy twice as much as you need now and hoard it for future use (which should get you through your years of ownership, plus some)
