porthole
RogerRose
porthole
Post by RogerRose »
1981 37ft sedan with three portholes. How do I take them out without breaking them. I took out all screws around frame. but they seem to be one piece. No wood frame, just plastic porthole then wall.
Thank You
RogerRose
Re: porthole
Adhesive fighting you?
RogerRose
Re: porthole
Post by RogerRose »
YES, not sure about that does the inside porthole trim ring separate into two parts? inner and outer or one piece
Re: porthole
I'm afraid you're gonna have force things and hope for the best.
Re: porthole
You might look on the computer for a new one and get some idea how they are put together. Some glues will soften with heat, so you might try a hairdryer to heat it up first.--Ed
l98ycar
Re: porthole
Post by l98ycar »
I had two of them out on my '78 over the winter, one to replace and one to re-seal. Remove the outer trim ring and the screws on the inside, removing the outer trim should let you get in and cut the adhesive/sealant. I might still have the broken one at home and could take some pictures but there is not a lot to them. There was no sealant on the interior side of mine, just the outside.
Scott
1978 Marinette '37 Dual Cabin
440 Chryslers
RogerRose
Re: porthole
Post by RogerRose »
pictures would help.
Thank you
Roger
