Firing Order / Timing Problem?
duke52
Post by duke52 »
Hey guys. I need some of your Marinette wizardry.
I had my starboard 318 stall out on me when coming back from my first cruze of the season.
I chalked it up to running the boat low on gas and likely sucking up some garbage from the bottom of the tank.
I had been having what seemed like a fuel starvation issue last season that led me to change the fuel pump.
Thinking I had just misread the signs I replaced the carb with a edelbrock 1409 and swapped the spark plugs.
Thinking I had caught an error from winterizing I moved a few plug wires around, I then proceeded to moving all of them (knowing that I shouldn't, but the auto mechanic in me thought not big deal I've done this a million times) - long story short I'm pretty sure I've messed up the order.
I've followed the firing order cast into the manifold, and found what I believe to be TDC with the thumb trick on cyl 1.
Cranks but no start, even with a quick squirt of starting fluid no hazza.
Sounds like it's got compression, but I haven't done a compression test.
Here's the part that has me scratching my head. The best I can tell the rotor is pointing between Cylinder 1 and 8 at TDC - considering I haven't pulled or loosened the distributor it doesn't make any sense that it would be off.
What do you think the odds are that the timing chain jumped a tooth? Am I missing something?
Also I muddled with distributor a bit and may have the pick up gap off - it appears that my advance springs are warn too...
Thanks in advance!
29' FBS, 318's
Tranquilo
Re: Firing Order / Timing Problem?
Post by Tranquilo »
Verify this:
http://www.marineengine.com/boat-forum/ ... 1308966639
Use a compression gauge to verify the pressure of #1. You can't easily find TDC that way but you'll get a good idea as to where the compression stroke is. Check voltage at the coil and make sure you have spark.
If you used starting fluid and it didn't turn over a little bit, you need power
duke52
Post by duke52 »
Thanks Tranquilo. I was just reading your thread about your Petronix install.
I'll put a gauge on it, but I'm fairly certain I've found the compression stroke (jumped the solenoid with my thumb on the plug hole - cranked until I was able to identify with reasonable certainty where tdc was - something to note for other when they come back to this thread is that if you crank from the control panel with a compression gauge you need to pay attention as the gauge holds the pressure reading so be sure you put the gauge in a spot that you can see it so you don't miss it.) I'll report back if I was off.
I'll check the voltage at the coil and jump it if need be to eliminate power to the coil as the cause - it's an old coil so I may swap it out to be sure I have a strong spark.
I pulled the coil to dist cap wire and cranked it to see if I had spark and had an audible arc so I think I've got spark.
Do you happen to know what the clearance should be for the pick up in the distributor? Could my meddling with it be messing with the timing?
Thanks again.
29' FBS, 318's
Had to laugh at your plight! (Sorry.) Been there, done that, tore out some of my remaining hair, etc.
The "mechanics" at my old slip did a compression test on my starboard motor (for the insurance company--long story). They mixed up a couple of wires--which is damn easy to do on SB Mopars since the wires are jammed between the manifolds and valve covers. After hearing a 'pop' at 2,500 rpms on plane (she still jumped out of the water) I started changing parts until I stumbled over the truth (by pulling each wire out of the cap, one at a time). Since you can't get her to fire up, your problem is worse than mine!
Okay. A few questions....Did you remove the distributor from the block? If no, then # 1 cylinder should be (on the cap) at around 10:30 to 11:00 o'clock. Standard or reverse rotation, # 1 is on the front left side (except for vee-drives, where the motor is in assbackwards). Next, determine if it's a Standard or Reverse Rotation motor (starboard on twins is a RR, and also in most singles). The firing order on the cap should proceed CLOCKWISE in BOTH cases, with 18436572 for normal rotations, and 12756348 for reverse rotators.
Next, find and correct (if it's off) the # 1 wire. LABEL the plug ends with duct tape and a marker to avoid future confusion. Take one wire at a time, going clockwise around the cap, and make DAMN sure it ends up where it should go! (If in doubt, double check.) Then try to start her.
One of two things will happen: It will 'behave' (after a bit if coaxing) or it backfire, try to start, fight the starter, etc. If it does nothing at all, either you're ignition is not putting out the usual 1/2 inch long BLUE spark, or it's seriously messed up.
If you did pull the distributor, then it's now either 180 degrees out or spot on--it ain't a Chevy that can go in a zillion different ways. Correct or 180 degrees out--no other combo is possible.
Good luck!
If you think you are 180 degrees out, ( timed to exhaust stroke instead of the compression stroke ) just move all the plug wires half way around the dist. cap --Ed
duke52
Post by duke52 »
Thanks for all the help guys!
I had the firing order reversed as FastJeff pointed out (could kiss you buddy).
I was confused by the incorrect firing order cast into the intake manifold.
I should have known better and double checked.
I'll be happy cruising on Lake Lanier this weekend thanks to all your help!
29' FBS, 318's
You'll remember that now! Standard intake on a reverse engine. Correct for the other engine.
..."I had the firing order reversed as FastJeff pointed out (could kiss you buddy). "
As Patton once said (when a drunk Russian general wanted to kiss him). "If I had known, I would have shaved extra close this morning!"
legendlc
Post by legendlc »
Hope no one minds me bringing this post back from the dead. I have a pair of 440's that the PO removed all plug wires from the spark plugs on both engines. The plug wire ends have 2 different numbers on each of them and when tracing back to the distributer on the port side engine they don't seem to match the counter clockwise rotation of 1-8-4-3-6-5-7-2 or the clockwise rotation that escapes at the moment. I have seen several post of plug wires backwards and switched and have been reading for 3 days on various websites etc and the only thing that I have concluded is that I am lost. My port engine rotates CCW and I am assuming that cylinder#1 is front left cylinder. I replaced my distributor with it at TDC and the rotor facing what I believed at that point to be the plug wire for the #1 cylinder. Now after putting the top on and looking at my wires from PO not only do some appear to be switched but it looks like some are even on the wrong side of the engine(I could be totally lost). If anyone has any links, or knowledge or just a good guess at this point I would be very appreciative. Thanks in advance and hope everyone is doing well.
1978 37 Double Cabin
Lake Cumberland KY
No problem. Start with the standard engine first. You can make any wire on the distributor #1. I would advise you get a Motor's manual from the library, or go to a NAPA for a picture handout. You will see in a Motor's or Chilton that you number the cylinders from the front left. So left side is 1357 and right side is 2468. On both engines. (Fords are numbered differently ) You have to put #1 on compression stroke, turn the crank in the direction of rotation until the timing mark lines up. Drop the distributor in. Make sure the rotor lines up with one nipple or wire on the cap. This is #1. Turn the distributor until it just fires. So you made it fire at the right time for #1. ( make sure you know which way the crank turns) Then you have to know which way the rotor turns. It will move a little in the direction of rotation if you try to turn the rotor. ( because of gear backlash ) So start with #1, go in the direction of rotation of the rotor and put in the next wire according to the firing order. Put in the rest of the wires and run the engine to make fine adjustments on the carb and timing. I prefer a vacuum gauge for fine tuning. Then do it again on the reverse turning engine. Be advised the firing order may be on the intake manifold. Will be correct on the standard, will be wrong on the reverse engine. The rotor will turn the same way on both engines. PM or call me if you still have a problem, I can walk you through it over the phone.-Ed
