capac sensor
capac sensor
Is there a source for a replacement hull sensor for the capac system? I have been searching all over the www and have come up empty handed.
Re: capac sensor
Capac may have morphed into this company, Evoqua:
http://www.evoqua.com/en/brands/Electrocatalytic
It's worth a call to their tech support people, Good luck
Re: capac sensor
Post by Maestro »
There's also this one: http://www.boatzincs.com/corrosion-refe ... trode.html
It's a basically a portable handheld CAPAC meter. You connect it to a Digital Multimeter and to the hull put the reference electrode over the side of your boat and into the water.
Re: capac sensor
Maestro wrote:There's also this one: http://www.boatzincs.com/corrosion-refe ... trode.html
Come to think of it, Jeff years ago made one and loaned it to me to compare to the Capac built into the boat. It was accurate. A little less convenient but quite handy. Readings don't have to be continuous. So just use it periodically and you'll have peace of mind
Re: capac sensor
Mine used a probe on a cable (forget where I bought it) and a cheapo Harbor Freight meter. You clamp the meter's negative ground to a railing, toss the probe over the side, and read the 'CAPAC' data on the 2 volts scale.
Re: capac sensor
Boat Zincs probe is the way to go. I have used one for years to test other folks boats and calibrated the CAPAC on mine with it.
Now the best way it to drop the probe in have a cold one then check the readings. It takes a few min. to stabilize. Use for DC bonding tests etc. Use the digital volt meter to test for stray AC current. You pretty much have it covered then.
Re: capac sensor
Found it! Wards Marine Electric in FL is the supplier. You can still buy the whole system new, or the parts.
tjcimba
Re: capac sensor
Post by tjcimba »
I replaced mine a few years ago and went directly to Siemens. Identical including the butyl seal material.
here is some contact information from my 2012 email.
Siemens Industry,Inc
2 Milltown Court
Union, NJ 07083
Email: rosanna.valle@siemens.com
Phone: (908) 851-6915
Fax: (908) 851-6906
www.siemens.com/water
hope it helps.
Re: capac sensor
Post by Maestro »
Can I ask how much it costs for the new system? I have heard this can be a pricey option.
My CAPAC still works but the outer silver chloride surface is very dirty. I have been advised not to scrub at it. Basically keeping my fingers crossed that it stays working. I have checked it with a multimeter and it does read correctly despite the grime.
Re: capac sensor
It was 600 and some change for the entire kit. Just the through hull was a little over $300.
