Stalling near dock
Ryan
Stalling near dock
Post by Ryan »
I have been stalling out around the dock (at idle) the last few times I have been out. It started with my Starboard engine but yesterday it happened on my port also. It happens when I'm in gear and maneuvering in and out of my dock. I'm idleing at about 680rpm normally. I'm going to change plugs and wires. Do you guys recommend anything else? I have electronic ignition.
Chrysler 360's
Cleveland, Ohio
whoward
Re: Stalling near dock
Post by whoward »
might be the computer control module, or gas, do you have water separators on?
Cap and rotor. Wells is a good brand :!:
Stay clear of Sierra . :roll:
Check the vendors list for part numbers.
:o might be the computer control module . :? Don't think an 86 had a computer. :roll:
Before you jump into ignition related issues... Both engines.... not likely the problem.
Start with the easy may fix....
Buy carb cleaner or Sea Foam.
Start engine and start pouring into the carb throat. Flood it to kill the engine.
Let sit for 20 min. or so....
back up...
Spray additional cleaner this time do not kill engine.
If your jets are clogged it sometimes will clean them out.
I also have used MMO and did the same thing but slower.
If not... tear down carbs and clean. (at least the jets)
Ryan
Post by Ryan »
I normal run a gallon of sea foam through half way thru summer,I have yet to do it... I'm going to do the plugs, wires, and sea foam and see what happens. If it comes to it where would I find the computer modualar on the motors ?
Chrysler 360's
Cleveland, Ohio
ECU rear of engine under cover
BALLAST RESISTOR
COIL
Post by tundrarules »
Bad batteries will cause weak ignition. If you are using parallel swith to start stalled engine the bat is weak.
Not ecu with both acting up.
Is your fuel old?
Did you add fuel cleaner to the tank? That will knock gunk loose in tank... Not recommended :shock:
Both carb idle circuits may be clogged. Screw the idle circuit screw out and in a few times try, that should clear trash.. Count turns :shock: then try sea foam in the carb like the guys said. If you have the original carbs you may want to consider updating to edelbrock carbs.. Easy install. Check national carburetor online.
Let us know what you find.
:ugeek:
collins69s
Post by collins69s »
To me 680rpm seems too low for idle AND manuvering.. Especially if you are stalling when switching from FWD to REV.. Seems to me my rpm I would set at 750-800 while manuvering through the marina.. There are two different idle adjusting screws on your carbs. One is for low idle if I remember correctly.. My '32 did this same thing and I adjusted those and all was well. Remember to try the EASY stuff first. It's too easy to over complicate small issues and you can't get time back wasted on goose chases. Let us know!
Sean
Inland C's
ZF Trannys
Port Clinton, OH
1972 32' Marinette FB Express
Siff Surf
Twin Chrysler 318s
Port Clinton, OH
Chrysler engine manual says 600-700 rpm idle in gear.
balthaus
Post by balthaus »
Ryan,
Any progress?
I am having similar issues with both motors. Motors stall as trans is engaged.
Problem will correct itself, after idle-ing or sitting with motors off for a while, and then re-appear.
1984 32' Sedan FB
Twin Chrysler 360's
1.52:1 Velvet Drives
Ohio River
