Shaft logs
Calivanos
Shaft logs
Post by Calivanos »
Okay so do Marinettes have shaft logs or are those just pipes that have been welded in? My port side pipe/shaft log is the last of my hull or drivetrain issues. I can stick my finger through it. What should I do?
Help!
Calivanos
1964 31' Marinette Cabin
Matagorda, Texas
Re: Shaft logs
Aluminum pipe welded in place :!:
Find a friend who knows how to weld aluminum or buy a sh%$ load of JB Weld. :roll:
Re: Shaft logs
First: Why can you stick your hand through it? Corrosion, Damage?
The log MUST align properly with the strut. If not welded properly or out of alignment... it will not last long and will further complicate operation.
The shaft DOES NOT TOUCH THE LOG.
The log also need to be the same grade aluminum as the hull.
With all the workboats used in Texas it should not be difficult to find a marine yard that can repair the log without issue.
Calivanos
Re: Shaft logs
Post by Calivanos »
Yes sir corrosion damage, ate right through what appeared to be a weld.
Calivanos
Matagorda, Texas
vtomica
Re: Shaft logs
Post by vtomica »
What is a shaft log?
Vtomica
'73 32'FB twin 318's
'88 235 Weekender Sea Ray
Kinzua Dam - PA/NY
Re: Shaft logs
Post by Maestro »
vtomica - a shaft log on a Marinette is essentially an aluminum pipe that the propshaft travels through in order to exit the hull. As Dave mentioned above, the propshaft does not actually touch this tube at all. A watertight seal is created by the packing gland which is tightened on the shaft and is clamped to the shaft log.
If you google image search "shaft log diagram" you'll quickly see how it works.
Calivanos
Re: Shaft logs
Post by Calivanos »
I wanted to share the final product. This is the starboard shaft log. I had extensive damage on the port side and welded thin plate over it. Bill said use a $h1tload of JB weld and I decided to do just that as well. For good measure I pored about a 1/2 inch on the starboard side as PO had obviously tinkered around there. Now both look like this.
(It's Belzona by the way) radical industrial stuff sort of like JB Weld
Calivanos
Matagorda, Texas
collins69s
Re: Shaft logs
Post by collins69s »
That Belzona seems like some bada$$ stuff. Did some research on it. Which product did you use?
Thanks!
Sean
Inland C's
ZF Trannys
Port Clinton, OH
1972 32' Marinette FB Express
Siff Surf
Twin Chrysler 318s
Port Clinton, OH
Calivanos
Re: Shaft logs
Post by Calivanos »
I had all sorts of ideas as I have witnessed repairs to hydrocarbon processing units and even seen machined parts. The Belzona folks talked me into pouring in 5831 to a thickness of about an inch. I am in awe of the strength. I have never seen anything like it. Built in galvanic corrosion protection a plus. A tech offshore claimed he would dip a brush in it and brush pipe stantions submerged in salt water and It would still stick and cure. Warning though it is more expensive that you can imagine. 500-750 gallon
Calivanos
Matagorda, Texas
