spark plugs
seef158
spark plugs
Post by seef158 »
I am going over and getting running the 1978 28 express I just got. I looked up the plugs in a book and it said Champion RN12yc were the right plugs, I pulled the old plugs yesterday to put oil in the cylinders and the engine had RN14yc plugs in it.... Which is correct?
forest lake, mn
Duluth, mn
Washburn, wi
Re: spark plugs
I'm running RN9YC plugs. Pretty sure the manual calls for RN9YC, at least for the mid eighties 360 Chrysler's.
According to Champion the 9,12&14 are the same spec except for the heat range. Looks like the 14 is at the top of the hot range, then 12 and 9 in the middle range.
"heat" refers to dissipation at the tip of the plug.
Plug info
http://matchlessclueless.com/mechanical ... mperature/
Can also google for the Champion plug heat range pdf document.
Re: spark plugs
IF you do a lot of cruising on plane, a slightly cooler plug would be a good idea. That's what we do, and I've seen the plugs run a bit too hot for my tastes.
But if you only plod along off plane, a bit hotter plug MIGHT make 'em run better.
Re: spark plugs
Post by ericinga »
You can find spark plug information at www.sparkplugs.com. I run AC Delco R44XLS which is essentially an Autolite 65. The next cooler plug is an R42XLS (Autolite 63). Since the plugs are readily accessible, I run less expensive copper core plugs.
Re: spark plugs
Checking the articles referred to in the post just above and on another thread, the conclusion is very important:
It is also important to remember that it is better to err on the side of a spark plug which is too cold, rather than one which is too hot. At worst, a plug which is too cold will result in fouling which can easily be remedied with a quick change, but a plug which is too hot could cause severe engine damage
Re: spark plugs
Post by tundrarules »
1985 twin 318s. I usually go slow around our lake. I am planning on using the hotter Champion RN11s in the aft 4 cylinders because everyone says those cylinders foul plugs faster due to running richer than front four cylinders. I will use the oem RN9s in the forward cylinders.Seems logical.....
:ugeek:
Re: spark plugs
WHat you are thinking about sounds interesting. But I wonder why Chrysler didn't recommend that practice in their engine manuals.
Re: spark plugs
Got this idea from FastJeff (I think). Maybe Chrysler tested engines in a level configuration. The slant in our engines cause the rear cylinders to run richer than the front. I am grasping at straws, but that is all I can come up with. :mrgreen: I will try it out. 1 step hotter than oem plugs. Not even sure that will make a difference.
I am running a Pertronix flame thrower coil and wires. I have been running them for 3 seasons now with no issues. I will be changing plugs in a few weeks. It will be interesting to see how the soft Champion plugs held up to the higher voltage coil. I will report my findings. Jeff chime in if you have tested the hotter plug application.
:ugeek:
spdracer
Re: spark plugs
Post by spdracer »
RN12YC is what Champion recommends for today's fuels in the small blocks.
Chris Hamann
Lakeland Auto & Marine
Port Clinton, Ohio
