Reinstalling heads/exhaust
legendlc
Post by legendlc »
Head finally came back from machine shop now it's time to start re-installing everything. Any tips/tricks out there? Would love to hear them if so. I have exhaust system fully disassembled down to the end caps on the logs. Newly rebuilt head that had to have valves reseated and one totally replaced and everything clearanced.
1978 37 Double Cabin
Lake Cumberland KY
Re: Reinstalling heads/exhaust
I find it helpful to get the studs to hold the manifold and gaskets in clace. I also use a long bolt with the head cut off to hold the exhaust hose in place to get the bolts started. Go back and re torque when it has been run.
my 2 cents
1. Use the best damn head gaskets you can find!
2. Put a LIGHT coat of silicone on both sides of every exhaust manifold/ riser/ etc. gasket.
3. As Wayne said, retorque the head bolts after the motor is up to temperature.
legendlc
Post by legendlc »
Jeff, any recommendations on head gaskets? I have a fel-pro PermaTorque blue stripe to go back on but can change that easily as I won't start on the head for a few days.
Lake Cumberland KY
Good choice.
legendlc
Post by legendlc »
Jeff, would you put silicone on head gasket? If I remember correctly the parts guy said to not use any on it?
Lake Cumberland KY
A thin smear of it around the water passages won't bother a thing.
legendlc
Post by legendlc »
Much appreciated sir.
Lake Cumberland KY
Difrenzi
Post by Difrenzi »
I’m looking into a possible blown head gasket on a 1977 318 28’ fly ridge. The motor has 1,800 hours. My question is with this many miles does it make sense to repair and replace only the upper half of the engine. Any advice will be appreciated.
Boat is in eastern Kentucky. Cave Run Lake.
It depends on how much damage the break in the gasket did to the BLOCK. obviously, the head can be replaced without hauling the motor out, but if the gasket break "fire gouged" the block you're screwed.
That happened to me. Ran less than a half hour at cruising speed and the damage was done.
