trans noise
trans noise
Postby ddependo » Wed Mar 13, 2019 8:25 am
OK Marinette brothers, Have a new one for me.
Just completed fixing ring gear on port engine. Got everything back together and starts fine but makes a clunking noise in neural at all rpm range. Put in gear , forward or reverse and noise goes away. Sound like it is coming from area of damper. Damper looked ok when apart . Any suggestions. I don't think I have enough blood left to take it all apart again. Rough job for a old man!
Re: trans noise
Postby Fastjeff » Fri Mar 15, 2019 1:20 pm
Bad damper plate (sprngs).
Re: trans noise
Postby EWRice » Fri Mar 15, 2019 3:55 pm
If it didn't rattle before, but rattles now, I might suspect the bolts mounting it to the flywheel didn't get tightened. At least those can be checked through the timing hole.
Re: trans noise
Postby javalin390 » Sun Mar 17, 2019 4:03 pm
Not sure if Chryslers suffer the same issue, but the flywheel on GM engines sometimes crack around the bolt holes at the crankshaft, which causes a clunking noise in neutral.
