Engines ready to install, Finally!
Alright, both engines are together and running. Any leaks have been repaired. Now working on engine compartment getting it ready!
- Attachments
- IMG_0945.JPG (63.56 KiB) Viewed 28750 times
Steve and Mary Levi
1973 32' Marinette Fisherman
SBC Crusaders
El Ohssa
St. Joseph, Michigan
SBC Crusaders
El Ohssa
- ThunderStruck
Re: Engines ready to install, Finally!
Nice !
Mike Calp
ThunderStruck
1978 32' FB Sedan
Middle River,Md
ThunderStruck
1978 32' FB Sedan
Middle River,Md
hightension
Looking good
Rodney Hack
Louisville,Ky
1975 32' sedan flybridgehttp://www.marinetteboat.com/forum/ucp.php?i=u ... =signature#
Louisville,Ky
mgoblue9798
- New poster
Nice. Did you get remans, or did you to through them yourself?
I tear them down, machine shop does all of the work, then I put them back together and hope for the best! I am from a generation that rebuilt the engines in the cars we drove several times over! Small Block Chevy's are pretty simple
Steve and Mary Levi
SBC Crusaders
El Ohssa
SBC Crusaders
El Ohssa
..." I am from a generation that rebuilt the engines in the cars we drove several times over!"
Ditto! Good luck.
Ditto! Good luck.
Did you have your transmissions rebuilt too?
Did not rebuild tranny's. Just replaced fluid. Money runs out eventually!
Steve and Mary Levi
SBC Crusaders
El Ohssa
SBC Crusaders
El Ohssa
Know that all to well, I was afraid not to have them done. Everything seemed fine but while they were out went ahead and bit the bullet.
While they are out: Plumbing for head, blower motors, all wiring and battery cables, 120v breaker box, all new motor mounts, new prop shafts, props, bearings, rudders, battery boxes, all new exhaust hoses, fresh water strainers, water separators, fuel line - should I continue? Oh, and the cost to rebuild 2 small block chevy's and add fresh water cooling system. After that, the boat will still need to be stripped an painted, and aluminum tubing for rails replaced with stainless along with new bases. Also need to redo helm with gauges I can read. Would not mind a boat cover as well. Should have got into boating when I was 20, will never get all of this done!!!!!!!!!!!!!!!!!!!
Steve and Mary Levi
SBC Crusaders
El Ohssa
SBC Crusaders
El Ohssa
