WANTED Prop LH 16 x 15 x 1, Neutral Safety Switch Cover
Looking for a couple things. Need the cover plate for a velvet drive that houses a Neutral safety switch - just need the cover plate. Also, need a prop that measures 16 x 15 x 1 - LEFT HAND ROT.
Steve and Mary Levi
1973 32' Marinette Fisherman
SBC Crusaders
El Ohssa
St. Joseph, Michigan
SBC Crusaders
El Ohssa
Re: WANTED Prop LH 16 x 15 x 1, Neutral Safety Switch Cover
Do you need the blockoff plate or the mounting plate for the switch.
CaptainOpus
There is one in Cleveland Craigslist
Thanks Captain Opus. Mounting plate is what is needed on the tranny for the switch. I have switch and thingy that goes under it.
Steve and Mary Levi
SBC Crusaders
El Ohssa
SBC Crusaders
El Ohssa
Shoot - 1 1/4 on the bore - could sleeve it but would rather not.
Steve and Mary Levi
SBC Crusaders
El Ohssa
SBC Crusaders
El Ohssa
I have the mounting plate you need. Let me check my prop wall and see if i have what you need. It would need a tune up if i have one.
Your boat have 1 inch shafts? Better check that one to make sure with twin 360's .
Big
's Rule !!!
Big
I checked my props and every one is RH. No 16s either.
