Chrysler Engine Manual
Engine manual for 1988 '32 FBS Sedan. Chrysler 318's
ChryslerEngine.pdf
(1.43 MiB) Downloaded 977 times
Re: Chrysler Engine Manual
Joel, thanks for the post :!:
I have a question on the PCV system on Chrysler Marine engines. On page 15 figure 9 shows the flow for this set up.
My question is my starboard engine is set up like the picture. I would like to reverse the location of the valve covers. This would help when trying to fill engine oil after oil change. Pain trying to fill thru the tiny PVC valve hole on this engine. :x
If your engine does not have the twist in oil cap, you don't have to switch valve covers, only the grommets for the pcv and breather/oil fill. If you have the twist in cap, then unfortunately you do have to swap the covers.
