Replacing my 318 with a new 360
Tranquilo
Post by Tranquilo »
Hey guys,
So I'm almost done with my home remodel and am starting to plan my spring time activities with my boat.
I started it up and it was knocking really bad. So I guess getting water in that cylinder did her in.
That said, I want to upgrade if I'm going to do all that work and $$ and the 360 gives me a bit more for the same money.
I want to just buy the long block package for $2500 (http://www.atlanticmarinestore.com/5-9- ... ong-block/) and put all the upgrades I did for my 318 on it.
As I understand it, I'll need a 360 specific oil pan, damper, flywheel
What else would I need that isn't in my list?
Re: Replacing my 318 with a new 360
Right, and front mounts are also slightly different (I'm told). It would be a good move to locate a junker 360 and steal the parts you need for a long block won't have any of that stuff.
You'll need a prop upgrade as well--about 2 inches more pitch.
barefoot99
Post by barefoot99 »
I did this complete swap 3 years ago. I can help with parts even, if needed. Send me a PM and we could talk over the phone about things if you like.
I posted a complete run down of the job as I completed. May be able to find some of it in a search, the engine section seems to be missing from the past.
-Scott
SUP !
1982 32 Sedan FB
2269 hrs
360's-Edelbrocks, DUI
Norris Lake
Speedwell,TN.
Tranquilo
Post by Tranquilo »
Thank you!
Scott, I'll take you up on this :)
Jeff, good call. I'll search craigslist and ebay
I would be interested in a confirmation on the front engine mount differences. It has been a few years since I did a swap. I don't remember the mounts being different.
I do have an oil pan, windage tray and oil pump for a 360 if you need one. As well as other parts for early LMs.
