Impeller size for a 440 Chrysler
Anyone out there have the info needed for an impeller for a 330 hp 440 Chrysler?
Thanks,
legendlc
Re: Impeller size for a 440 Chrysler
Post by legendlc »
I've got one in the package I think in the new to me 37 that just got delivered down here to lake Cumberland. I will try and go take a pic for you. Although I can't load pics here as I don't understand the sizing limitations.
1978 37 Double Cabin
Lake Cumberland KY
legendlc
Post by legendlc »
Well I was mistaken I have a used impeller it's a jabsco and has a part number of 18948-0001. It is a 12 vane impeller I assume came out of my 440's. I have a spare here labeled gen that is much smaller. Hope this helps.
Lake Cumberland KY
Trowerpower
Post by Trowerpower »
Depends what pump you have. They used a number of them depending on the year. My 87 has Sherwood G7 pumps on it. Impellers should be replaced every two years. Good luck!
Trower Power
Blue Sky
Performance Distributors
750 Edlebrocks
fresh water cooled
1.5 to 1 velva-drives
Onan 6.5kw gen set
metalmanbret
Post by metalmanbret »
If it's an 80's 440, it's the same as an 80's smallblock. Sherwood 10615K. I have the same on in both my 39' and 28'
