Sea Cocks 32 Express Hardtop twin 318
baymarinette
Post by baymarinette »
I'm replacing my old gate sea cocks ( disaster avoided )and went off and left the old ones at the boat without measuring the size. Since my boats a 4 hr trip right now, I'm hoping one of you know the size I need. Will continue to use bronze rwc strainers.
Any suggestions as to type and maker would be appreciated as well.
I've been a long time visitor and just finally joined because this is the only question that I cant seem to find the answer for.
Thanks in advance!
Roger2
Re: Sea Cocks 32 Express Hardtop twin 318
Post by Roger2 »
I don't know the size for your boat but I would replace with "Marlon", a very strong plastic material.
Roger
Roger Brown
Petersburg, IL
Second the idea of using Marelon. One suggestion on sizing -- if you have to guess, buy a couple of different sizes (if the marine store is near you) and return the ones that don't fit.
UPDATE: Down below, you'll see a suggestion about using bronze. As long as the bronze is isolated from the hull, it does, in fact, last quite a long time. Boat US praises marelon for thru hulls vs whatever the usual plastic devices are made of. Ordinary plastic is subject to relatively quicker degradation which means it's ok until suddenly it isn't which is not what you want for thru-hull material. There's lots of material to be found quickly on the web doing a search for through hulls/marelon/bronze sea cocks. The Boat US publication that covers the subject is "Seaworthy". Look there for some articles of interest. Marelon is a product of the Forespar company.
baymarinette
Marelon really? For sea cocks? I know they make great thru hulls
The old gates were bronze...
baymarinette
I've got bronze basket thru hulls to the sea cocks
GB49
Post by GB49 »
I'd stick with bronze for anything under the waterline.
Forum member since 1998.
Post by barkleydave »
Here is a source:
http://www.forespar.com/products/boat-m ... hull.shtml
Notice they recommend using epoxy to attach the scoop to the hull.
Other choice could be use the Marleon for thru hull/ and put bronze valve like a Perko or Groco, or Buck Algonquin.
1" 1/4 size
Roger2
Post by Roger2 »
I have Marlon sea cocks & Marlon 1/4 turn valves also.
Roger
Roger Brown
Petersburg, IL
baymarinette
Thanks folks.
so whatcha gonna do?
