From the pic, anode looks good. Cleaned up it should be good to go for another season. useful life is said to be when it reaches 50% of its orig size. I would take two half shot anodes and put them together.SunbeamIV wrote: The anode is probably 6-7" long. Do you think that it has life left in it?
Hull Preparation & Painting
Re: Hull Preparation & Painting
OK guys. This sounds like you are very serious about your bottom paint. I have a workboat quality Marinette 32 express cruiser. What is the least expensive way I can bottom paint it, with the least expensive bottom paint?
Thanks,
Bruce
Thanks,
Bruce
Bruce,
I got my 2 seasons ago and after I hauled it the first time, the bottom needed painted. First I sanded the entire bottom with a palm sander to remove loose and flaking paint. Any bare aluminum spots were quickly wiped with denatured alcohol and spot painted with Primocon underwater primer. I then painted the bottom with "Shelter Island Plus" copper free antifouling bottom paint.
It held up fine last season and probably won't need anything this spring except a few touch ups.
I'm in fresh water, so I didn't see the need or have the time to get too carried away making it perfect.
Located: Edgewater Yacht Club
Lake Erie
Lake Erie
- shade2u2
I've found that I have bare aluminum showing about 18" along the bow keel. This could be from me pulling into a sandy beach area a couple of times last season. If I sand this area and paint it with 3 or 4 coats of Interlux's Interprotect 2000E, will this paint act as a tough barrier or "keel guard" or will this likely occur again? I will top the 2000E with Interlux 33.
You're asking too much of paint. It's not there to protect a very exposed surface (and a pointy one at that) from beachings. Either accept that running the boat onto land will scour the surface or find a product (they are out there) to cover the keel. Bottom paint exists to thwart algae and critters that want to attach to the hull, not as a guard against abrasion. Nor is it designed to ward off galvanic action though it helps a wee bit
- shade2u2
I figured the 2000E wasn't super-magic-hardcoat paint. I got a dinghy last year to get back & forth to the islands so that I would scrap the hull. This year we have a sea-doo also. We'll anchor out.
thanx
thanx
Somebody makes a plastic keel protector deal that attaches to the keel. (Forget the manufacturer.) Supposed to eliminate that problem.
- shade2u2
I looked into the "keel guard" products. I was concerned about it bending & wrapping around with our sharp deep keels. All the installations that I saw were on fiberglass like hulls.
thanx
thanx
An epoxy coating will hold up much!!! better than anti fouling in a beaching situation. I have a friend who used an epoxy that was sold for water tower interior liners and it was amazing at staying put after all the anti fouling was worn off from beaching. I have 2000E on mine but have not beached my boat enough to advise if it is as effective as what he used but I have hopes is it. I would also guess that muddy mucky Ohio beaches are less abrasive than the nice sand I wish we had...
- shade2u2
I finally got some time from work and decent weather to get the first coat of bottom paint done.
It's so late to not be in the water yet...
