Hull Preparation & Painting
Re: Hull Preparation & Painting
Post by shade2u2 »
Here are a few ugly mucky low quality pics before power washing:
BOW KEEL...
SIDE...
RUDDER & PROP...
TRIM TAB...
STERN THRUSTER...
Good series of pix. They make a good case for power washing on haulout and not letting the stuff dry
Post by honestcharlie56 »
excuse the ignorant questions, but is that a stern thruster?
SunbeamIV
Post by SunbeamIV »
John,
Thanks for posting. It looks like you may be missing the 12" anodes that get bolted to the trim tabs. On my M, those seem to be the ones that wear away fastest.
Located: Edgewater Yacht Club
Lake Erie
Post by shade2u2 »
jralbert wrote:Good series of pix. They make a good case for power washing on haulout and not letting the stuff dry
Yep. That was my plan but the water service at the ramp was closed and by the time I got it home I had to leave for work. I'll post some after power washing pics sometime. It didn't come out to bad, but it would have been easier when still wet.
Post by shade2u2 »
honestcharlie56 wrote:excuse the ignorant questions, but is that a stern thruster?
Yes it is. It works great & looks better now that it is washed. I will paint it also.
Post by shade2u2 »
SunbeamIV wrote:John,
The trim tabs have anodes on the top of the tab behind the lip - can't seen them in the picture. I don't have pics showing the anode. I'm removing them this weekend to clean up and re-install. They still look pretty solid.
Post by shade2u2 »
Here is the after power washing. The anode is probably 6-7" long. Do you think that it has life left in it?
Post by shade2u2 »
Here is the stern (thruster & rudder) after powerwashing. I'm going to removed the anode, clean and remount. I'm going to clean up the rudder and possibly paint with 2002E. The thruster had antifouling paint on it also but the powerwashing took most of it off.
Post by shade2u2 »
This is the bow keel after power washing. I may try some hull cleaner for the white paint above the bottom paint line.
