I am rebuilding a pair Chrysler 318s and I did not take notice of the plumbing of the fresh water cooling system when I was disassembling the motors. Now that I am replacing all of the hoses, do I have to switch the inlet and outlet on the reverse rotation motor?
Both motors have non-directional pumps.
Reverse rotation engine fresh water pump connections reversed?
Re: Reverse rotation engine fresh water pump connections reversed?
Hello, First the hoses are the same. The pumps are the same. One pump body will be 180 of the other. Look and see if the pump body doesn't show the direction of flow. Them figure out which way the belt is turning. I hope this make sense. The hose on the bottom is intake, the hoes on top is out put. Joe
I am not sure that is the case here. Here are photos of both the port and starboard engines I took before I disassembled everything and the orientation of the pumps are the same. Any ideas?
- Attachments
- port 4.jpeg (36.42 KiB) Viewed 17161 times
- stb 4.jpeg (37.77 KiB) Viewed 17161 times
I'm gonna try to upload my sketch of which way everything goes. This site has tight restrictions on file size, so it might not work.
Here goes...
Here goes...
This is a diagram of the raw water impellers, right? I am talking about the fresh water pumps bolted directly on the engine block.
Yes. Hoses are not reversed. Direction of vanes are.
Follow Jeff diagram it is perfect.
The fresh water pumps on marine engines are not directional (same pump for regular and reverse rotation motors). The vanes are straight. A car water pump is directional, though. See the images
Although he says fresh water pump, I believe he is talking about his raw water pump. But as always, I could be wrong.
