prop shaft isolation help. Drivesaver not an option
Re: prop shaft isolation help. Drivesaver not an option
>> coupler passes the bolts through but they screw into the flange. Makes the heat shrink impossible.
Actually, you may be able to do the shrink tube...
captpaddwheel
Post by captpaddwheel »
Anybody in need of a pair of #504 Globe DriveSavers new in the box? Wouldn't work on my 34' without shaft machining. Will sell em for $150.00 ea. plus shipping.
yooper
Post by yooper »
My boat has the original couplings but they shafts are not isolated. They conduct current just fine. It would be nice if I could order a kit that has all the non-conductive elements in it. Kind of like a gasket set you can buy for an engine. Included should also be the shaft bushing. I hate the idea of disconnecting the coupling and then floundering around looking for a part.
Post by Joe »
I will buy them. I was looking at a set. Joe
yooper wrote:It would be nice if I could order a kit that has all the non-conductive elements in it. Kind of like a gasket set you can buy for an engine.
John Althouse had them but, sadly, I don't think he can supply for a while at least. Meanwhile, the diagram above should be good guidance for everyone.
captpaddwheel
Joe,
Send me your contact info to: paddwheel@comcast.net
We can figure out best way for ship & pay.
Thanks, Greg
