Trim Tab Pump
seef158
Trim Tab Pump
Post by seef158 »
I had forgotten that the trim tab pump was missing on my 1978 28 express that I just picked up and got home. I noticed it last fall when I inspected the boat but forgot all about that. Does anyone know what model pump will work with my system? It has the original joystick style switch on the dash if that matters. If anyone has a 28 that they could grab the pump model off of that would be much appreciated. Thanks for the help in advance folks. :mrgreen:
forest lake, mn
Duluth, mn
Washburn, wi
Re: Trim Tab Pump
If it's Bennett tabs, their web site says they make two hydraulic pumps. You should call them to learn which fits your needs. If it's another brand, check their sites and tech departments
Re: Trim Tab Pump
Post by barkleydave »
Give Bennett a call GREAT FOLKS TO DEAL WITH! They will be able to sort it out for you and provide fantastic customer support !
Harryb
Re: Trim Tab Pump
Post by Harryb »
Hi the bennet pump you need is probably the V351 it is a small pump and fluid supply combined and uses 1/4 inch plastic lines with compression fittings. It is a very common pump and the only one I have seen on marinette's. BigM
seef158
Re: Trim Tab Pump
Post by seef158 »
Thanks Harryb. I have been looking at them and that is what I thought I needed but wanted someone to confirm.
forest lake, mn
Duluth, mn
Washburn, wi
mlklusman
Re: Trim Tab Pump
Post by mlklusman »
Same pump on mine.( Bennett) Might be the only one Marinette used. I replaced mine 5 yrs ago . Must be well made for mine was 38 yrs old when replaced.
No matter where you go, there you are
Knot Normal , 28ft Express
Ten Mile TN.
