Off season fuel conditioner
Post by shade2u2 »
What do you add to the tank for the winter?
Why did you pick that one?
Getting ready to top off the tanks for the season end.
Re: Off season fuel conditioner
I always used a "stabilizer" called Sta-bil. Can't say why I used it. At the same time, I always took mfr claims with a couple of grains of salt. But I didn't want to chance a bad outcome and it was relatively cheap stuff. I never saw any objective article reporting on independent tests of stabilizer concoctions. I think fuel additives are somewhat over-hyped.
Others on the forum may be able to point to good reasons for one brand over another... or any brand for that matter
UPDATE: Got un-lazy and thanks to Google found this citation on testing: https://www.boatingmag.com/gear/boating ... ers#page-3
ANOTHER UPDATE: make sure some of the stabilized fuel is in t he carbs before hibernation - that is, run some thru the engine before you winterize.
carl
Post by carl »
I've also used Startron. Not sure if it's any better (or worse). The main thing is to fill the tank(s) full as possible with conditioner, then run the motors a bit to get it into the fuel system.
Here's a piece of good news on this hotly debated subject: This summer was such a mess--way too hot, then raining like crazy, then... repeat. I filed the tank of my 19 footer last November with that 10 % ethanol crap, stabilized the fuel, and burnt only half of it this entire year. Still, the motor ran just fine. I intend to pump the rest out before refilling with fresh gas and more stabilizer, but that really old gas DID run fine.
PS: Boat is stored outside.
Post by shade2u2 »
Thank you for the details.
Good information.
