Re: A little crazy?
Posted: Thu Mar 21, 2024 8:45 am
That's very impressive speed and mpg figures! My win 360s equipped, 32 footer did 20 mph at a best of 1.2 mpg.
A forum for aluminum boat owners and those directly supporting them
http://marinetteboat.com/forum/
As somebody who has taken a Marinette hull way way outside its design parameters. Just be careful running those speeds for the first time. My experience is on a 28, my 32 is stock.TinLizzy wrote: Tue Mar 19, 2024 6:01 pm Tracy, I also am very curious. On a 25 Bayliner flybridge with a single 454, my father switched out a bravo 2 for a 3 about 15 years ago. It gained about 3 to 5 mph at 3200 cruise. Pessimistically I think it will run about 32 to 33 mph at my cruise rpm of 3,000. Optimistically, I will be tickled if it will run about 35 mph. The drives came with 24 pitch props, which may or may not work, I won't know until my first water test. I have a single set of 26 pitch, so I would have to get one more set if the 24's don't work. I pulled the prop shafts out and looked at the gears and bearings and they looked good, so hopefully I can get a few years out of them.
I assumed you would be careful. I was just taken by surprise how quickly it went from stable to holy crap. I am just wrapping up the seakeeper install on my 28 with the outboards. Hoping to get it in the water for testing mid-May as well.TinLizzy wrote: Wed Apr 03, 2024 1:28 pm Tracy, I will definitely be careful. I have hit 44 w.o.t during prop tests. It does feel a bit strange, but not unstable. I'm hoping to be able to trim a bit more with the duo prop, which I think will help that, but I also only go w.o.t for testing. I have ran it at 35 mph on shorter outing, and I handled well with the Bravo 1, so I anticipate it will also be stable with the Bravo 3. Hardest part is the waiting. We have had an extremely mild winter, but as of late, winter has come back with vengeance. We are in a winter storm warning as I write this. I think it will be mid/late May before I can launch it to find out.
It is installed and ready to go. Seakeeper should be out in the next month to commission it. Personally, I am hoping for such a beautiful season that I never even need to turn it on.TinLizzy wrote: Wed Apr 10, 2024 5:44 pm I will be interested in seeing how the seakeeper works. Sounds like everyone loves them, everything except the price, quite steep. Good luck with the install.
Gotcha. I was excited to hear about it.TinLizzy wrote: Tue Apr 29, 2025 4:49 pm I did the Bravo 3 last summer. They actually did not perform as well as expected. I lost both cruising speed and fuel mileage at 3,000 rpm. Went back to a newer set of Bravo 1's for the rest of the summer. Going to try to come up with a set of Bravo 2 drives. I think it will like the added diameter of the props on those. Still fighting the issue with not being able to trim the outdrives much while on plane. The bravo 2 driveshafts are 2 inches lower than the bravo 1 or 3, so hopefully that fixes it. It snowed here today, and we still have snowbanks here, so it is going to be a bit before I will get it in the water.
