Joined: 2/27/2010 Posts: 64 Points: -52 Location: Florence KY
Okay here goes, I have gotten two quote's on a new 75 gallon aluminum tank and Wow this is not going to be cheap.700 to 900$ I looked in the tank and is speckled with rust, my question is, is there any way I can clean the tank without removal? If so what do I need to use? I have water separators and inline filters before the carbs. Whats the worst case scenario? filters clog and engine stall? I am going to replace it but would like to get a year out of it if possible. Rob
Joined: 12/7/2007 Posts: 445 Points: 711 Location: Alpena, Michigan
Don't know if I done right but then I could remove my tanks.
First I drained them, removed them, flushed out the residue (rust and stuff) with H2o, and soaked up the remains. Then I poured a gallon or two of acetone down them and drove around with them in my truck bed for a couple of weeks to slosh it around real good and cut the varnish. Could have put some ball bearing in there to help but why get more anal.
"When THE PEOPLE fear their Goverment, there is tyranny. When the Goverment fears THE PEOPLE, there is liberty." Thomas Jefferson
Joined: 10/25/2009 Posts: 186 Points: 9 Location: Marblehead, Ohio
I bought a 1974 SAAB Sonnett a couple years ago and the gas tank was totally messed up. I pulled the tank, took out the sending unit and dumped probably two gallons of sludge and stuff that looked like white paint chips out.. Then I washed it out with my hose, threw a bunch of nuts an bolts in it and sloshed it around, banged on the sides with a rubber mallet, and washed it out again. I repeated this until not another speck of crap came out. Then I took it to a self serve car wash and blasted it out with high pressure water and soap for about ten minutes. Took it home, plugged a hair dryer in and let it run in the big hole for like a half hour or forty five minutes.. Then I took a torch and heated it up all over an watched whatever remaining water there was evaporate. Reinstalled and never had another issue. So how to do this on a Marinette without pulling the tank.. The first thing is how to drain it completely and get all the crap out before you start flushing it with water.. I don't think there is a 3 or 4 inch fitting on the bottom side to remove and drain is there? If you could, then I would get a snake like you use to clean a floor drain and put it in through the top, like at the gas gauge opening..It does come out, doesn't it? Then put the snake in there and just let it rattle around in there and flush it with water, and repeat till nothing else came out. Then just dry the crap out of it. Hair dryer, block heater, what ever I could fit in there to heat it up.. That's my theory.. But you have to get all the gas and crap out and start flushing with water or you'll have a big bang theory on your hands..And face.. And everyone else in the marinas hands and face.. Probably better to pull it.
Joined: 10/27/2008 Posts: 173 Points: -1,109 Location: sunsetbay lk erie WNY
ok worst case first a hole rots throuhg, gas leaks in bilge pumps o/b or blowes up from, spark. now 700 is a little steep ill call my shop and see if he still has a big truck tank he can modify to your aplication , i run through cincy all the time and ill bring it to ya for freee. jeff likes that .so give me a call and we'll seee what we can do. they built big m's out of aluminuim and they said it couldn't be done and show me a dosen to one 73 glass jobs still on the h2o 716 923 3148 its not that bad of a job
HP Sunset Bay lake Erie NY boat name Sunrise 32' f/b fisherman"It would be a labor of love, if I loved to labor" cpt Brent
Joined: 12/5/2007 Posts: 275 Points: 536 Location: Cleveland, OH
$700-900 may not be cheap, but piece of mind is priceless...
, Member
Joined: 12/4/2007 Posts: 1,311 Points: -1,496 Location: White Lake MI. or on my BOAT
Rob, Don’t cut corners on “SAFETY PLEASE” yours & your families lives are at stake on this one. That galvanized tank is 37 yr old. Why play Russian Roulette with 5 bullets in the revolvers chamber.
Big s Live On Keep your hooks wet & your Butts dry also make sure your whistle stays wet
Norm, I understand and agree. Jeff had told me this early on when I had asked this question prior to me getting prices. I will go the route of a new tank and remove the old one tomorrow. I might have to stop drinking beer so I can afford all these projects I have to complete. Thanks, Rob
Joined: 12/7/2007 Posts: 916 Points: 1,087 Location: Central Florida and the DC area
I would at least look at Flounder Pounder and other surplus places before having a tank made. The going rate for used tanks is around $4 / gallon.
 Rank: Member Groups: Member
Joined: 3/10/2009 Posts: 29 Points: -10 Location: Columbia TN
Joined: 7/27/2008 Posts: 91 Points: -6 Location: louisville ,ky
a friend of mine in louisville ,ky has a alum welding shop he will build that tank for about 400-500 if your going to replace it try just take it out and clean it with nuts and bolts or pea gravel and hot water like collins69s said we used to do that all the time in the junk yard
mark http://www.outdoorstokerboilersofky.com/
Joined: 12/10/2007 Posts: 415 Points: 1,002 Location: Lake Michigan
Most marine insurance companies will refuse to insure a boat with steel tanks that old. My brother in law had to replace his tank on a '77 F-32 Trojan last year before his carrier would renew his policy. Check e-bay. From time to time they have great deals on fuel tanks from boat builders who are either hybernating or out of business. I agree with Doug about Flounder Pounder. I've purchased a few things from them and had very good experiences. p.s. Here's a link to the Coast Guard regulations covering fuel systems: http://law.justia.com/us/cfr/title33/33-2.0.1.8.44.10.html
Joined: 12/7/2008 Posts: 64 Points: 198 Location: Charleston WV
Rob First any "marine FUEL tank will not have a drain in or near the bottom. You do not want a plug in the bottom of a FUEL tank that can become loose & leak. If you were to sell this boat @ some future time a surveyor would point these out instantly ! Becareful of using truck fuel tanks most have a drain in the bottom & most are steel & will rust & corrode in a damp enviroment . I know of a couple of companies that make plastic fuel tanks in all sizes & shapes & they are more a fordable than the $$'s you are talking about. Senor moment keeping me from naming them now but I will look them up & post soon. Dave P.S. ComputerJoe Can you add spell check to this site?
, Member
, Member
Joined: 12/5/2007 Posts: 2,473 Points: 4,333 Location: New Tripoli, PA
On another web site where I dispense equally bad advise, I had the nerve to suggest selling some really old gas that had been sitting in the guy's fuel tanks for years. He was going to pay the marina $$$$ to remove; instead, he sold for $$$ to a guy on eBay, and that guy did all the work!
Should have gotten a commission on that deal, but...
"There is another class of coloured people who make a business of keeping the troubles, the wrongs, and the hardships of the Negro race before the public. Having learned that they are able to make a living out of their troubles, they have grown into the settled habit of advertising their wrongs -- partly because they want sympathy and partly because it pays. Some of these people do not want the Negro to lose his grievances, because they do not want to lose their jobs." Booker T. Washington
Update, I was able to remove the old tank today. It was very close but I didn't have to cut any of the bracing.Ya I am planning on having the new tank the same dimensions but I might shorten it a little. I might drop the size to eighty gallons. I also shopped vac the entire engine room, wow all kinds of stuff in there leaves, nuts bolts zip ties a shoe and more. Lol I will keep you guys posted on my progress. Thanks, Rob
, Member
Good man, Rob. You made the right choice.
You might want to get a quote from http://sptanks.com/
Guest2 |
