Gray marine fireball 327
Hyperjump
Post by Hyperjump »
After winterizing my 327 gray marine fireball engine, mechanic said needs rebuilt. Another mechanic said just heads and a carb .They both said that motor was designed to run leaded gas not ethanol gas. She spits carbon out exhaust and I had to put 1 to 1-1/2 quarts of oil every few times running her. Shes not leaking oil in bilge . Motor runs strong, just not sure what road to take. Just wondering if its worth the money to rebuild or swap out for a either a 318 or 360 Chrysler , or a 350 Chevy . Parts for either of them are easy to come buy. My boat is a 1966 26 ft express. Either way I go shes getting fixed. Any suggestions ...... Thanks
:D HYPERJUMP :D
1966 26 Ft Express
Saybrook , Ohio
Lake Erie
Re: Gray marine fireball 327
I will start off by saying this about the 327: it is an expensive overhaul. The 327 I rebuilt for my Thompson I think I had around $1900 just in parts. Add machine shop bill and we've exceeded $2700. I had good exhaust manifolds which was a plus. If you do need to rebuild, ask yourself how much you like that 327.
That being said, make darn sure that your engine needs overhauled before taking that leap. Its good you got a second opinion, maybe a third is necessary. Don't tell them what the first two told you either. The Rambler engines were known for valve guide issues so I wouldn't be surprised if that was your issue. If that is the case, the Rambler is an easy head job. This would be a good opportunity for a machine shop to install hardened exhaust seats. This is a MUST if your heads are being rebuilt.
A good mechanic will be able to do a leak down test on your engine and verify where the problem lies. Also, without any tools, you can pull the valve covers and check some of the valves for play.
The condition of those hard-to-find manifolds should be what decides the issue: If they are bad, look for another engine.
Hyperjump
Post by Hyperjump »
Thanks to all. Going to do some more digging into my motor. I hope its just head job.
:D HYPERJUMP :D
1966 26 Ft Express
Saybrook , Ohio
Lake Erie
Have you figured out the plan of attack on your engine? Found this on craigslist... https://detroit.craigslist.org/mcb/bpo/ ... 79450.html
The manifolds--impossible parts to find--look fairly good in that photo.
Leviathon
Post by Leviathon »
Nice looking complete engine listed in Detroit Craigslist for $500. If you want to stay with Gray, I would snatch that up for spare parts in a second.
Steve and Mary Levi
1973 32' Marinette Fisherman
SBC Crusaders
El Ohssa
St. Joseph, Michigan
That is one of the rare "bobtail" engines for V drive, jet drive or other isolated drive setup. I have never seen one other than in the service book.
Post by honestcharlie56 »
That won't last long.
