new fuel lines
Posted: Wed Sep 21, 2016 11:45 am
by ukester
any one redo there fuel lines-did you use braided lines and if you did did you use nipples on the fuel pump and carb?
Thanks Mark
Re: new fuel lines
Posted: Wed Sep 21, 2016 4:48 pm
by barkleydave
Use only USCG approved alcohol resistant lines for hard runs copper. Believe the rubber lines are Type A or A-1 3/8 inch ID Nipple are used on pump outlet and carb inlet when flexible fuel line is used. OEM used steel line from Pump outlet to canister filter then steel or copper to carb. Might have been different on pre 80's boats.
USCG/SAE J 1527 Type A1 ISO 7840-A1 CE
I have not seen an approved braided line.
Safe boating,
Re: new fuel lines
Posted: Thu Sep 22, 2016 4:59 am
by ukester
when replacing the carb to a new edelbrock the fuel line is different -making a new hard line with a fuel filter is what I made up but with the vibration I am looking for a different way-I was going to use stainless steel braided to run over the exhaust manifold so it would take any heat from the manifold and be safer to all the vibrations on the engine. your thoughts?
Mark
Re: new fuel lines
Posted: Thu Sep 22, 2016 6:38 am
by MetalHead
Re: new fuel lines
Posted: Thu Sep 22, 2016 8:51 am
by barkleydave
Thanks MetalHead for posting the info! Great source material.
Re: new fuel lines
Posted: Thu Sep 22, 2016 11:05 am
by EWRice
When going to the Edelbrock carb, you just need the brass adapter to go from 5/16 to 3/8 inverted flare. Most parts stores should be able to get it. Summit or Jegs has them too.
Re: new fuel lines
Posted: Thu Sep 22, 2016 3:38 pm
by Busia
ukester wrote:when replacing the carb to a new edelbrock the fuel line is different -making a new hard line with a fuel filter is what I made up but with the vibration I am looking for a different way-I was going to use stainless steel braided to run over the exhaust manifold so it would take any heat from the manifold and be safer to all the vibrations on the engine. your thoughts?
Mark
Do not run any type of fuel line near the exhaust. Even engine coolant is too hot. The fuel will boil and you will have vapor lock and no fuel to the carb.--Ed
Re: new fuel lines
Posted: Thu Sep 22, 2016 4:39 pm
by ukester
so how hot does the exhaust manifold get on a 440 Chrysler-my recollection is it does not get too hot to the touch.
Re: new fuel lines
Posted: Thu Sep 22, 2016 4:45 pm
by ukester
this is the fuel filters being used
Re: new fuel lines
Posted: Fri Sep 23, 2016 8:44 pm
by spdracer
When using a 1409 or 1410 Edelbrock we reuse the original Carter fuel inlet nut. The threads are an oddball size. Makes swapping into them a snap.
