No Charge Chrysler 360 Port side Engine
Posted: Sat Aug 13, 2016 12:53 pm
by nascarjonb
I am kind of stumped because I have no voltage from the regulator to the alternator, but when I jump the regulator wires i still have no charge. I have verified that i have no resistance in the feed wire from the regulator to the alternator and i have ran a jump wire from power side of regulator straight to alternator post. Could I have a bad Alternator AND a Bad regulator? or is there something else im missing?
Re: No Charge Chrysler 360 Port side Engine
Posted: Sat Aug 13, 2016 4:01 pm
by balthaus
Are you checking with a multi meter or guages?
Posted: Sat Aug 13, 2016 4:18 pm
by spdracer
If you have power to the main stud on the alternator (Orange Wire) jump to the field terminal (Green Wire) from the regulator with the engine running. If it doesn't charge then the alternator is junk. The common failure is the rotor. It usually open circuits. Another test on the engine is see if you have continuity between the field terminal and ground. If you don't, you know the rotor is open or one of the brushes has an issue. Make sure the green wire is disconnected at the alternator. Yes, if the rotor shorts, if can take the regulator with it. With the key on, regulator case grounded, and 12V to the red plug on the regulator, the stud that the green wire connects to should have 8-12V on it. If it doesn't, its junk as well.
Posted: Wed Aug 17, 2016 10:25 am
by nascarjonb
I am using a DVOM meter and I will try that jumping trick next time I'm at the boat. Next weekend. Thanks for the input I will
Post back my results
Posted: Mon Aug 29, 2016 11:29 am
by nascarjonb
I have determined that the alternator is junk and the regulator is junk as well... i am thinking of my options but I am leaning toward a one wire alternator system... has any one had any experience in this?
Posted: Sun Sep 04, 2016 7:48 pm
by meltonhill
Might be of assistance, I'm having the same problem currently. I've finally tracked mine down, to the voltage regulator field relay.
Posted: Mon Sep 05, 2016 8:18 am
by barkleydave
IMHO one wire only way to go. You will need to run heaver gauge (6AWG) wire have a good ground, and go directly to each batter. Be sure to fuse the positive output to the battery with the appropriate size fuse. Put fuse as close to battery try to keep it within few ft.
I have had my one wires running now for 10 years they work great !
#40112
http://www.arcomarine.com/xhtml/Pages%2 ... nators.pdf
Here is the company I used for comparison.
http://mascostartersandalternators.com/ ... etail&p=32
Posted: Tue Sep 06, 2016 7:26 pm
by nascarjonb
meltonhill wrote:5327168.jpgMight be of assistance, I'm having the same problem currently. I've finally tracked mine down, to the voltage regulator field relay.
wear is this located? also I DO have battery voltage on 1 side of the regulator...if the field relay is out wouldnt i have no voltage on the regulator?
Posted: Wed Sep 07, 2016 9:19 pm
by spdracer
That relay was only used 1971 and back with the Chrysler alternator. No need to run a 6 gauge wire. The 1 wire unit charges 60-75amp and the factory 10 gauge wire is sufficient.
Posted: Wed Sep 07, 2016 9:25 pm
by meltonhill
Mine is located above the transmission next to the voltage regulator.
