Carb rebuild time?
Posted: Mon Jul 25, 2016 11:24 am
by railrunner04
Well the old girl is now having ignition/fuel problems it seems :roll: backfiring under load at 2400 to 3k and losing power thinking it's carb rebuild time they havent been touched in 10 years never had any issues dont fix it if it aint broke right ;) just want to get some opinions on where the best place to start is. Probably going to go cap rotor plugs and wires first to rule that out but I am suspicious of the carbs and probably rightly so :roll:
Thanks in advance
P.S. bill your experience is hauntingly familiar :shock:
Re: Carb rebuild time?
Posted: Mon Jul 25, 2016 1:06 pm
by ericinga
Before tearing into the carbs, grab a timing light and verify ignition advance at 2,000+ RPM. If you don't have at least 20 degrees of advance, the advance weights might be rusted or an advance spring may be broken. Easy fix and might only cost you an hour and a few squirts of oil.
Posted: Mon Jul 25, 2016 2:53 pm
by railrunner04
ericinga wrote:Before tearing into the carbs, grab a timing light and verify ignition advance at 2,000+ RPM. If you don't have at least 20 degrees of advance, the advance weights might be rusted or an advance spring may be broken. Easy fix and might only cost you an hour and a few squirts of oil.
I didn't even think of that! I'll have to check into that first
Being that the issues start at 2k your probably right :idea:
Posted: Mon Jul 25, 2016 3:53 pm
by ericinga
If you need help, contact Ron Spies. Hes a FYC member and a Marinette owner. Lives 1 mile from the club.
Posted: Tue Jul 26, 2016 7:58 am
by Tuggle
Carburetor Specialists in Alpharetta, Ga. did mine, 678-393-1501, not cheap but all things considered happy with the results.
Posted: Tue Jul 26, 2016 10:59 am
by railrunner04
ericinga wrote:If you need help, contact Ron Spies. Hes a FYC member and a Marinette owner. Lives 1 mile from the club.
Will do that for sure going to check the basic simple stuff before we call the calvary. I'm sure he's quite busy with that awesome 34 he just acquired. Looking at that boat makes you wonder what might have been if the company had continued on :)
Posted: Tue Jul 26, 2016 11:03 am
by martindesign
90%of carb problems are ignition problems. I wouldn't get into that carb at all.
Posted: Tue Jul 26, 2016 1:46 pm
by ericinga
Pure "boat porn" for the 70 year old. He has always wanted a '34 and couldn't wait to get his hands on it. In all honestly, he could spend 10 minutes on your motor and save you hours of time. He has not forgotten much from his ASE certifications.
Posted: Sat Jul 30, 2016 3:26 pm
by bill
He got me on the right track and back into boating. :D
