HOW TO: Low Water Pressure Alarm System (FastJeff Page)
Posted: Mon Apr 27, 2015 9:06 am
by jtalberts
Low Water Pressure Alarm System:
Question: How long will a Raw Water Cooled motor last running along on plane if the raw water supply is suddenly cut off (by a rag over intake, thrown belt on pump, broken hose, etc)? Thirty seconds! Furthermore, the temperature sensors and alarm switches don’t work properly when not covered with water, so you can’t count on the gage or alarm system to save your motor. Obviously, another system is needed.
The system I developed (which is similar to those used on some modern outboards) is to monitor the raw water pressure. You’d be surprises how low this pressure is: At the exhaust manifold, at idle, it’s only 1 psi. The pressure rises to about 5 psi at 2,000 rpms—still low but still usable for a pressure switch.
You’ll need one adjustable pressure per motor. I found some switches on eBay that were adjustable from 1 to 6 psi—-perfect. I also located some 12 volt buzzers for the alarm. A trip to Radio Shack supplied the toggle switches. The wiring diagram (see sketch) is fairly simple: 12 volts goes to the switch, then to the buzzer, then to the pressure switches, with other side of the switch to ground. The box with the buzzers and the switches was then mounted near the helm. Install a tee in the intake manifold and screw in a barbed fitting (available at a hardware store). Run a hose from there to the pressure switch, and be sure to use a clamp at each end.
Note: The following is for raw water cooled engines ONLY.
Note: Mount the pressure switches close by and on the same level as the motor if possible. The bulkhead works well (see photo).
Calibration of the pressure switches is simple: Fire the engine, turn on the alarm, and adjust the pressure switch(s) until it sounds off. Next, rev the motor to 2,000 rpms and slowly turn the switch until the alarm turns off. (This takes two people.) Finally, drop the rpms back to idle and the alarm should go off. (If not, readjust.) This can be done in the slip for the water pressure there is the same in idle as when under way.
In operation, I flip the alarm toggle switches to ON then plane off. The beeping ends soon as the rpms come up. Dropping off plane, the beeping begins again soon as the motors settle down to idle. This provides me with a system check.
