What size marine AC system do owners have on their 28' Express?
The boat is in GA and experiences 90+ degree days from June to Sepetember. I used rough volume measurements, did not subtract for interior components, used a load factor of 19 and came up with 12,000 BTU.
Specifically, I'm looking at a Flagship Marine system. I was planning to over size the system to 16.5K BTU. According to them, short cycling would not be an issue with this size unit and it only cost a couple hundred more. I like the Flagship system since the design avoids the use of circuit boards, does not use reverse cycle heating and has thicker materials.
Thoughts?
Eric
AC system size for 28' Express
Re: AC system size for 28' Express
I looked at this unit. I like the fact that you can run the heat while the boat is on the hard during the winter.
and its made in the USA.
http://www.ebay.com/itm/Marine-AC-16-50 ... 19fd67fd1d
Hows that new son of yours You got him driving da boat yet?
