31' Marinette
Posted: Thu Dec 04, 2014 2:28 pm
by Chessyman
I am looking for a weight on the 31'. I really like the legnth to beam ratio of the 9' beam models. I think it should run pretty economically at a semi-displacement speed. I am looking to purchase a single engine one, but I am leary of the resale on a 60's boat if I stick a bunch of money into one. MetalHead had some nice pictures of his.
I plan to use it in the Florida Keys in both the backcountry and out in the Gulf Stream.
Anyone with experiance who could let me know about the 31 would be greatly appreciated.
Re: 31' Marinette
Posted: Thu Dec 04, 2014 6:57 pm
by GB49
Resale on any Marinette is poor because they are top heavy, its not fiberglass and all the rivets loosen up over time.
Seriously,if resale is a concern, a boat is the last thing to invest in.
If the hull is in good shape, everything else can be cleaned up, rebuilt etc. The boat will last forever but don't expect to get your money back.
I think the older 60's/70's hull style are flatter bottom compared to 80's design. I'm told its more of a pounding ride but if your looking at a semi-displacement speed, that should not be an issue.
Only 2 things wear out on a Marinette, the engines and the owner.
Re: 31' Marinette
Posted: Thu Dec 04, 2014 10:34 pm
GB49 wrote:Resale on any Marinette is poor because they are top heavy, its not fiberglass and all the rivets loosen up over time. Seriously,if resale is a concern, a boat is the last thing to invest in. If the hull is in good shape, everything else can be cleaned up, rebuilt etc. The boat will last forever but don't expect to get your money back. I think the older 60's/70's hull style are flatter bottom compared to 80's design. I'm told its more of a pounding ride but if your looking at a semi-displacement speed, that should not be an issue. Only 2 things wear out on a Marinette, the engines and the owner.
Rivets? What rivets? I think that was a joke but your advice was sound. Boats, like diamonds, are a luxury, not an investment. Use, enjoy and get what you can when you are through with the fun (or the glitter).
Re: 31' Marinette
Posted: Fri Dec 05, 2014 1:28 pm
by ddependo
Amen on the "engines & owner" Sure glad I have two engines ,because I've come back on one many times. If I were in the gulf I would recommend twins. Get out of the way of storms when need to. Love my Marinette. Would not have anything else.
Re: 31' Marinette
Posted: Fri Dec 05, 2014 7:29 pm
by MetalHead
2 Engines - 3 times better than 1
.... Maybe 10 times better ... hmmmm
Re: 31' Marinette
Posted: Sat Dec 06, 2014 8:14 am
by GB49
jralbert wrote:GB49 wrote:Resale on any Marinette is poor because they are top heavy, its not fiberglass and all the rivets loosen up over time. Seriously,if resale is a concern, a boat is the last thing to invest in. If the hull is in good shape, everything else can be cleaned up, rebuilt etc. The boat will last forever but don't expect to get your money back. I think the older 60's/70's hull style are flatter bottom compared to 80's design. I'm told its more of a pounding ride but if your looking at a semi-displacement speed, that should not be an issue. Only 2 things wear out on a Marinette, the engines and the owner.
Ya, the rivet thing was a joke..... I wonder if someone makes a rivet tightener?
Re: 31' Marinette
Posted: Sat Dec 06, 2014 3:13 pm
by Busia
Loose rivets? You buck them.
Re: 31' Marinette
Posted: Tue Dec 09, 2014 10:10 pm
by Busia
No, really, thats what you do. That will tighten them up. Also if you are tired of overpriced drunks calling themselves marine mechanics, call around and see if you can find an aircraft mechanic that will fix your problems. A good aircraft mechanic is better and might be cheaper. After working on planes these boats are easy.---Ed (retired A+P )
