In order to effectively use the product, I'd have to put in a "T" in the fuel lines with a standard 6 gallon portable gas tank that would allow switching from the main 175 gal tank(s) to the treated 6 gal tank. It would be inconvenient to run through 5 gal, stop engine, transfer another 5 gal to the 6 gal portable tank, restart engine, run and repeat 2 more times (20 gal total), then repeat with the other engine. Having 2 portable setups would probably make more sense and not that much more money. To attain the correct the product's fuel/treatment ration using the main tanks would be unnecessarily expensive, hence the use of portable tanks.
Comments? Suggestions?
