Engine water pump
Knotty
Engine water pump
Post by Knotty »
I have a 1988 37’ with twin 454 engines and I’m trying to fine a reverse rotation water circulation pump, not the raw water impeller, I found this https://bpi.ebasicpower.com/shop/index. ... s_id=11607
This has a flexible impeller that can be used cow or ccw rotation, anyone know of this one? Or where can I find a replacement? I’ve looked at several sites and most are standard rotation pumps.
Knotty
Re: Engine water pump
Post by Knotty »
Edit: the impeller is brass.
The standard circulation pump work either direction. Mercruiser only sells one direction for both motors.
Knotty
Post by Knotty »
I found a couple unidirectional pumps.
