Corrosion question
Va7thson
Corrosion question
Post by Va7thson »
As the song says “Rust never Sleeps” Does corrosion continue when out of the water? My project doesn’t have an end in sight and So do I need to focus on the hull to some degree to stop the corrosion, or is it OK to continue working on the mechanical side? It’s been high and dry for years…
BlueSkye
Re: Corrosion question
Post by BlueSkye »
Probably not so much.
I've always stored my boat out in the weather but the only problem I had with the rain was rotting of the plywood deck in the cockpit. I replaced the plywood with HDPE sheet a few years ago and got rid of that concern.
1971 32ft Express 2x318
Inconsequential . In dampness, there's always some decay going on but it's tiny. There's no body of water through which the ions can travel to and fro.
Salty air, more but I assume that's not a worry for you.
