Carb recommendation
MissConduct
Carb recommendation
Post by MissConduct »
I am looking to replace my original Carter carbs on my 1982 32 with 360's. I had them both rebuilt last year, but one has a little leak and they seem to surge at the cruising RPM I like to run......any recommendations for replacements?
Thanks!
Jamey
1975 28 Express w318s
1982 32 Sedan FB w360s
Re: Carb recommendation
There's only one choice: Edelbrocks. They fit the carb flanges perfectly since they are modernized Cater AFBs.
While you consider Jeff's long-favored carb choice (he has always reported good results since he switched eons ago), have you replaced the little filter (CG 11?) at the mouth of the carb. When it clogs, it causes surging. It's cheap and sort of/kind of/moderately easy to replace.
The problem with the old Carter AFBs is flooding due to porosity of the castings (thanks t ethanol gas). Hard to fix that.
MissConduct
The Carters were completely rebuilt last summer. Still not right. I think new carbs is the way to go. FastJeff did you go with the 600 cfm or 750?
Jamey
BigM My final entry for this post. I found this gentleman. My problems were solved. https:carburetorsandmore.com Take a look at his website. Look at his YouTube videos My problem was the mechanical fuel pumps were over riding the carburetor float needle valves and flooding the engine out. :shock: I...
600 cfm is plenty. You run at part throttle, right?
SailFinn
Post by SailFinn »
Yoopers running at part throttle??? Come on now!
Well, most of the time, right?
With today's gas prices, running off plane may be necessary. Glad I'm now a kayaker!
TanakaMaru
Post by TanakaMaru »
Just replaced both on 1974 360's FlyingFish marine had them they are rebuilt not new but work great out for the box and half the price of Edelbrocks
Great company to work with
Bruce
Bruce
1974 37' Sedan Flybridge
Twin 360's
Old Hickory Lake
Mt. Juliet, TN.
