SOLD: 1975 28' MARINETTE EXPRESS
Posted: Thu Apr 22, 2021 7:12 pm
Boat and trailer are very clean and well maintained. Will be available for sea trials after June 15.
We are selling because we own a fishing boat in Marathon, FL and enjoy 5 months of winter fishing there. No longer have salmon fever.
Asking $20,000
https://www.dropbox.com/sh/9z95oara1e2x ... K3a?dl=0A
"SURFACE INTERVAL"
Home Port: Dewitt, Michigan
We found her at yachtworld.com in 2005. On the way to Eastlake, OH we picked up a new twin I beam aluminum trailer just south of Cleveland in Berlin Center. The trailer needed some adjustments and alterations, downtown Cleveland during rush hour was a bit stressful, and narrow toll road booths were a surprise. Luckily, we made it back unscathed.
Have made many upgrades: new paint on bottom (2006, 2010), new paint on top sides, gunnels and coamings, brightwork, new aluminum window tracks (2007-2008), hydraulic steering, (kicker has hyd steering and steered by autopilot), all new Raymarine electronics (2006), stern thruster (2007), fishing equipment and much more.
Always stored indoors. Yearly vessel safety checks performed by Coast Guard Aux. Maintenance record hard copy and on SD card with Microsoft Access database.
ENGINE: Single Chrysler 275hp (M360), new in 1987, 400 hours
TRANSMISSION: Borg Wagner - Velvet 1:1, R Rot, model AS1-71C
SPECIFICATIONS: Beam - 11ft, Stern - 9ft, Draft - 24"; 32" to propeller, Dead rise 10 degrees, 55 gallon fuel tank, 35 gallon fresh water tank, 15 gallon holding tank for head, 30 amp shore power with amp meter.
TRAILER:
Loadmaster tandem axle twin I beam aluminum trailer with electric brakes on all 4 wheels (4 new tires 2019, new brake assemblies 2014), posi-lube removable spindles, E-Z slide poly bunk pads, heavy duty custom made guides, PowerWinch RC30 with wireless remote control, spare tire with spindle, 4 Brownell boat stands.
13K BTU Carrier low profile air conditioner with heat - Model Air V (2008)
Remote control marine searchlight
Danforth anchor, rode locker, large sampson post, bow eye
Aft storage locker with vinyl seating cushions
Large custom made swim platform with removable 'tree' ladder for scuba diving and swimming
Spare propeller and shaft strut
Cockpit canvas enclosure (like new because we've have not used it)
BELOW DECK: V berth with 3" memory foam, stand up head with flush toilet and sink, two burner alcohol stove, refrigerator 115 volt only, microwave, sink, updated wood window blinds, garment locker, dinette table with storage under seats, storage racks and drawers.
HYDRAULIC STEERING SYSTEM - Ship - Seastar (5271 helm, 5313 cylinder), Kicker - Uflex UC132-OBS
STERN THRUSTER - 24 volt Navigator trolling motor with 55 LB thrust (2007)
KICKER MOTOR - 15 HP Yamaha (2003) 4 stroke with hydraulic steering (controlled by a 4 way hydraulic valve and steered by the autopilot), remote start/stop, tilt, and ConTrollKing throttle control. Kicker is wired to the ship's battery so it charges while trolling. Interlocking relay prevents kicker and main engine from running at the same time and prevents damage to charging systems.
SAFETY EQUIPMENT - Bilge blower, ACR 406 Cat II EPIRB (emergency position indicating radio beacon), Sea Fire automatic halon fire suppression, 2 fire extinguishers, Safe-T-Alert fume detector, Forespar TruPlug emergency plug, sounding bell, horn.
ELECTRONICS:
Raymarine E120 multi-function display (2006) with Navionics Platinum West Great Lakes electronic chart (2009)
Raymarine X-10 autopilot (2010) with type 1 hydraulic pump (2008)
Raymarine ST70 autopilot control head (2010)
Raymarine DSM300 digital sonar (2006)
Raymarine Raystar 125 GPS (2006)
Raymarine 4KW 48 mile radome radar (2007)
Raymarine Sirius Satellite Weather (2009)
Raymarine Ray54 DSC VHF radio (2008) FloScan GPS interface fuel flow computer (2008)
Engine compartment video cameras (2)
Smart Start - Relay and battery circuit that prevents abrupt engine starting current from resetting navigation electronics. (2009)
Custom engine monitor box with switchable piezo 100db alarms: LOW WATER PRESSURE, LOW OIL PRESSURE, HIGH ENGINE TEMP, HIGH TRANSMISSION TEMP, Digital display showing ships power and thruster battery voltages (selectable) (2007)
Engine room lighting (4 ignition proof fixtures)
Underwater lights (2) - 35W halogen
Step plate and courtesy lighting
LED spreader lights (2) Coastalnightlights.com
Jabsco 4 gpm wash down pump with HoseCoil side mount enclosure.
Bilge pump control panel (three bilge pumps: fore, amid, and aft)
2 bank battery charger for 24 volt thruster
2 bank battery charger for ships power
Battery switch for ships power
Digital engine and transmission temperature gauges
Raw water cooling pressure gauge and pressure switch (for detecting low pressure at output of pump impeller)
Bennett trim tabs with Trim Tab Position Indicator
Rudder position indicator
CAPAC galvanic activity monitor (model 50030)
ENTERTAINMENT SYSTEM:
Emerson 27" HD TV/DVD player, Clarion M455 CD receiver/CeNET control with CRMC1 wired remote control, Clarion DCZ625 6 disc CD changer, Shakespeare Seawatch 2025 marine amplified TV antenna system.
FISHING EQUIPMENT: (All new in 2009 and lightly used)
2 - Bert's 48" mounting track
2 - Big Jon electric downriggers with 52 inch solid booms, double rod holders, upgraded auto stops, and weight retrievers
2 - Big Jon quick slides
2 - Traxtech 3" swivel mounts
4 - Bert's ratchet rod holders
2 - Bert's accessory plates with Tite-Loc mini mounts and cannon ball rests
1 - Bert's tool holder
2 - Marinco 12 volt Pro Plugs and receptacles.
10 tube custom made aluminum rocket launcher powder coated to match boat.
2 super bright LED spreader lights
Fish Hawk X4 downrigger data system for trolling speed and temperature. Two spare probes.
2 Okuma Convector reels on MH dipsy rods.
4 Okuma CONVECTOR CV-45DX reels on Classic PRO GLT CP-CL-862M copper rods
OTHER STUFF: 2 Silver Mullet 10# downrigger weights - 2 Yeck 12# weights - 2 shark 12# weights Sapphire Chrome Shark, 4 planer boards - Telescoping fish net -Landing Loop docking aide
Asking $20,000
"SURFACE INTERVAL"
TRAILER:
ELECTRONICS:
