This one is a beauty
Found this while trolling thru craigslist https://quadcities.craigslist.org/boa/d ... 81727.html
Re: This one is a beauty
Post by Tuggle »
In pictures 14 and 15 there are two hoses running in a V off the prop shaft, in front of the shaft seal and behind the coupler, what are they?
Wow. That boat was done right. Very nice.
"In pictures 14 and 15 there are two hoses running in a V off the prop shaft, in front of the shaft seal and behind the coupler, what are they?"
Check out the link below for info on the 2 hoses.
https://www.tidesmarine.com/shaftseals/ ... nstall.php
Post by Tuggle »
Mine looks similar, less the hoses. Will look further into these, mine don't seem to leak, yet.
bryankephart
Post by bryankephart »
Tuggle wrote:In pictures 14 and 15 there are two hoses running in a V off the prop shaft, in front of the shaft seal and behind the coupler, what are they?
Those are dripless shaft seals. They use positive pressure from the raw water pump to push water out instead of letting it leak in. This lubricated the shaft seals. They are a replacement for normal packing.
Bryank97
Post by Bryank97 »
Man that paneling looks so good. I like the dull natural look of it. Wish i knew how to get mine like that
1988 Marinette 32 Sedan
Erie, PA
Twin 318 Chryslers 240HP
liquidplummer
Post by liquidplummer »
This boat is a beauty. I have had the opportunity to see this boat close up. It is a work of art, restored by a perfectionist.
Silver Queen St Louis Mo
