Voltage Regulator
wschneid
Voltage Regulator
Post by wschneid »
I have a 1986 Marinette 32 with the twin Chrysler 318 engines. One engine (alternator) is not charging. I had the alternator checked and it was okay. so I'm thinking it is the regulator. What type of regulator would it be? (part #, model) and where would it be located?
wschneid
Re: Voltage Regulator
Chrysler part # is 2847527, NAPA # is SME185710. Not sure where they are located on the 80's models. I do know that on the 70's models, they were wired thru the oil pressure switch, so if the oil switch went bad, the reg will not turn on.
wschneid
Post by wschneid »
javalin390 wrote:Chrysler part # is 2847527, NAPA # is SME185710. Not sure where they are located on the 80's models. I do know that on the 70's models, they were wired thru the oil pressure switch, so if the oil switch went bad, the reg will not turn on.
Thanks.
Post by Tuggle »
Converted mine over to one wire alternators from Arco Marine, internal regulators, never looked back.
The location of the regulator is under the black plastic box at the rear of the engine. ;)
ps
Please add a signature to your posting. ;)
Post by Tuggle »
Think Arco also sells a regulator, and yes it's under the black plastic cover, on the backside.
wschneid
Post by wschneid »
Thanks guys. I got it now.
Bill Schneider
