Having trouble with distributor cap hold down
Posted: Thu Sep 04, 2014 10:36 pm
by jmonday
My distributor hold down system is the stlye that uses a straight screw driver screw to tighten. The cap down. Anyone have a lead on where to buy them? Having trouble with play in the cap. Its a 1973 318 .
Re: Having trouble with distributor cap hold down
Posted: Fri Sep 05, 2014 4:17 am
You're saying the screw won't tighten up enough to hold the cap down?
Posted: Fri Sep 05, 2014 8:12 am
by jmonday
Yes. Or the cap is an automotive cap. Not sure so i would like to start with the correct parts on both. It has the old point system out and the electronic style of some kind in and i have a miss on top end. I have changed the timing and it helped for a day but then changed. Something is moving or breaking down. Just trying to find it.
Posted: Fri Sep 05, 2014 10:18 am
by ericinga
If you have the Chrysler electronic ignition system, check the reluctor and make sure it is tight. The timing on ours was jumping all over and found a loose reluctor to be the cause.
Posted: Fri Sep 05, 2014 11:44 am
by jmonday
Great thats a start. Thanks
Posted: Fri Sep 05, 2014 11:53 am
by jmonday
Hey Eric it looks to be a pertronics style but thanks anyway.
Posted: Fri Sep 05, 2014 1:51 pm
by bill
jmonday wrote:Hey Eric it looks to be a pertronics style but thanks anyway.
You can go to the Vendors list on this site or go to,
http://www.hurrikain.com/
Chrysler inboards
"ignition systems"
And then please add a signature to your post. :roll:
Posted: Sat Sep 06, 2014 4:27 am
The advancing mechanism tends to stick, which makes timing the motor at idle incorrect--the advance didn't come back to the idle position. That makes the motor retarded at WOT.
A few drops of oil on the wick under the rotor, followed by a few minutes of flipping the advance back and forth with one's fingers, often cures this problem.
Posted: Wed Sep 24, 2014 9:48 am
by jmonday
Thanks Jeff that was the ptoblem with mine. Im now helping a friend up the river a ways. Motor was running bad on starboard side so i swapped the dizzy do you know if i have to change position of the reluctor?
Posted: Wed Sep 24, 2014 2:58 pm
by barkleydave
No change to reluctor is required.
safe harbors,
