Borttom Paint and electrolysis
Posted: Sun May 24, 2020 9:41 am
32 Express
• capac read .9 all all last summer
• bottom paint shows some light popcorn/electrolysis
• anodes still look good - but showed some wear after pull out last october
• there was bottom paint underneath some of the anodes
• no anodes on prop shafts, not pitting on props
Action plan:
• vacuumed the entire hull -- currently pulled a red wire wired directly form the battery with painters tape at the end (uggh), plus a 1/8 cup of mixed metal debris
• sand the electrolysis spots, spot prime and paint
• remove all paint from under the anode areas so there is metal/metal contact
• apply new anodes from boatzincs.com (keeping old ones, but want to be sure we're starting from scratch to see results)
• added egg anodes to nshafts
• going to drop a second measuring device to see if it reads the same as the capac (test capac)
'• check galvonic isolator
• double check all ground
I think that should cover it -- if we pull up in the fall and there is no more electrolysis, I will soda blast the bottom to bare and get a solid bottom barrier on.
anything else to look for? capac seems deceiving, the numbers were in range and we checked often.
dont want to blast and paint if there's still evidence of electrolysis
JS9
Action plan:
JS9
