Chrysler 360 will not start post degreasing...
Re: Chrysler 360 will not start post degreasing...
Postby Fastjeff » Fri Jan 04, 2019 6:52 am
That's the Hall effect sensor. Replace it as well--they are cheap--and it HAS to work!
PS: You should see some resistance with a meter across the leads to it. If it's open circuit, that's the problem.
carl
Postby carl » Fri Jan 04, 2019 12:16 pm
Postby javalin390 » Fri Jan 04, 2019 5:42 pm
Yes, that is the pick up coil, and yes, the 8 sided thing on the distributor shaft is the reluctor. This is what is referred to as a hall effect or inductive trigger switch. It produces a magnetic signal every time one of the 8 blades passes by. Steam cleaning the engine could very well cause a pick-up coil failure. Mopar cars were notorious for that. The Chrysler electronic is a great system if one understands it. When you replace it, what a lot of mechanics don't realize, is you have to gap it just as you would gap old points, not just bolt it back in. If it is too far away from the reluctor blades, no magnetic signal will be generated. The gap is .035", I think but don't quote me. Use to be the only source for this spec was in a factory Mopar service manual, but I'm sure if googled it's online someplace.
carl
Postby carl » Fri Jan 04, 2019 7:13 pm
Postby Fastjeff » Sat Jan 05, 2019 7:27 am
Yeee-hah! Gonna be a good year.
Congrats.
