Calcium Chloride, Will it eat my M?
Studini
Post by Studini »
So I put a bunch of calcium chloride “B-dri” in my cabin to help keep moisture down but then started thinking I’ve seen chlorine airborne in a pool room eat out copper heat exchangers in pool heaters... any chance of calcium chloride affecting anything on the M?? First time with the M in winter.. just nervous..
88 32’ Fisherman
“Get Busy Livin”
Twin 360’s
Fairport Harbor, Ohio
Re: Calcium Chloride, Will it eat my M?
I know it destroys steel when in contact (look at old tractor rims that have been loaded). Brass gets a light green haze on the surface, but I can't recall seeing the affects on aluminum. I would think it would be similar to salt. Might only affect it with contact.
I believe it will cause pitting if it comes in contact with the aluminum.
I assume it's in a plastic container, sitting on a counter, not in contact with the hull. If so, it shouldn't be a problem. I used moisture absorbing stuff for years with no visible effect. There's another product - I apologize, I cannot recall the name -- that was good at reducing mold. It released a chemical that fought the airborne mold spores. Sold at West Marine
I also had a solar fan in the foredeck right over the v-berth. It ran continuously and kept fresh air flowing thru the cabin.
Studini
Post by Studini »
jralbert wrote:I assume it's in a plastic container, sitting on a counter, not in contact with the hull. If so, it shouldn't be a problem. I used moisture absorbing stuff for years with no visible effect. There's another product - I apologize, I cannot recall the name -- that was good at reducing mold. It released a chemical that fought the airborne mold spores. Sold at West Marine
Yes you got it! Just setting in the containers. I like the solar fan idea!! It’s my first winter so hot m not actually sure what to expect with moisture or mold.
88 32’ Fisherman
“Get Busy Livin”
Twin 360’s
By the way, those calcium chloride things do work so well they collect a lot of moisture - use a container that's large enough to accomodate it. Finally, one thing you can do to create air flow if you don't have a fan going is to crack a window or two but make sure they are covered well enough on the exterior so water doesn't get blown in - a little tricky.
bpboater
Post by bpboater »
Moisture absorbers are only effective in air tight compartments. At 70F and 40% RH, air contains about 10 grams of water per cubic meter of air. In a 32 foot Mrinette, there are about 60 cubic meters of air space. So, if there is absolutely no air exchange in the boat,you would need to collect 600 grams of water, or 20 ounces of water to get rid of all the moisture. I would guess that a 32 marinette with the standard windows and vents will exchange the air inside the boat about every 6 hours. So, in 24 hours, you would need to absorb about 80 ounces of water to make the air completely dry. Just reducing the relative humidity below 60 % is very helpful in preventing mold from growing. But, in the long run, abvorbing 20, 80, or even 200 ounces of water over a winter will do little to affect the relative humidity in the boat. Just take humidity meter and measure the relative humidity before and 7 days after you put the calcium chloride container in the boat.
1988 41 Marinette
Westerbeke 8.5 kw BTG
Lake Cumberland, KY
Follow on to bpboater's reply: Good thinking and analysis. The moisture things do work, but as bpboater points out, they only pull out a tiny fraction of the moisture inside the cabin over time. Like trying to propel the boat upstream with a paddle. So, while they "work", they don't resolve the moisture problem
Studini
Post by Studini »
bpboater wrote:Moisture absorbers are only effective in air tight compartments. At 70F and 40% RH, air contains about 10 grams of water per cubic meter of air. In a 32 foot Mrinette, there are about 60 cubic meters of air space. So, if there is absolutely no air exchange in the boat,you would need to collect 600 grams of water, or 20 ounces of water to get rid of all the moisture. I would guess that a 32 marinette with the standard windows and vents will exchange the air inside the boat about every 6 hours. So, in 24 hours, you would need to absorb about 80 ounces of water to make the air completely dry. Just reducing the relative humidity below 60 % is very helpful in preventing mold from growing. But, in the long run, abvorbing 20, 80, or even 200 ounces of water over a winter will do little to affect the relative humidity in the boat. Just take humidity meter and measure the relative humidity before and 7 days after you put the calcium chloride container in the boat.
Bpboater, thank you! That’s a lot of info! So the boat will be wrapped so i assume that may help with air exchange? So I guess I should not be that worried about the chemical reaction to the aluminum but more about the moisture content? Any suggestions on moisture removal? Maybe a solar dehumidifier?lol
88 32’ Fisherman
“Get Busy Livin”
Twin 360’s
bpboater
Post by bpboater »
I would suggest two things that are important. first, get all the water out of the bilge and open water sources, like the toilets. Next, create natural vents, so air can flow through and remove humidity that might build up under the shrink wrap. If the boat is shrink wrapped, you could leave the windows open a bit, so humidity is free to come and go. Maybe leave the hull portal windows open so the boat can breathe.
1988 41 Marinette
Lake Cumberland, KY
