360 valve cover gasket replacement
Studini
Postby Studini » Sun Nov 11, 2018 5:56 pm
Just got 32’ Fisherman and know the valve covers are leaking oil. Can the covers be removed and gaskets replaced without removing exhaust manifolds? It looks tight...
Also do you suggest cork or rubber and where would you get them from?
Thanks in advance for the help!!
88 32’ Fisherman
“Get Busy Livin”
Twin 360’s
Fairport Harbor, Ohio
Re: 360 valve cover gasket replacement
Postby Fastjeff » Sun Nov 11, 2018 7:17 pm
It can be done, but you'll need magnetic inserts in the socket to keep the bolts out of the bilge. Cork tends to compress and need retightening compared to rubber (which I prefer).
Postby Busia » Sun Nov 11, 2018 10:16 pm
Tighten them up first and see if they stop leaking. Everyone thinks they leak all the time, but a lot of times the oil is not from there. There is no oil pressure there so it doesn't take much to seal them.
Proud to be retired IBEW
Postby EWRice » Mon Nov 12, 2018 1:34 pm
Most manifolds will allow you to remove the valve covers but you will need a 1/4" drive ratchet, 6" extension, and either a short 7/16 socket with a universal or a 7/16 wobble socket.
Do try and tighten them first, but if they are cork they will leak again.
Felpro makes a marine specific gasket for these that if installed properly WILL NOT LEAK and the bolts will not loosen. It is a black rubberized felt material. I don't have the part number now but that is what I would use.
Studini
Postby Studini » Tue Nov 13, 2018 4:55 am
Thanks!! I did have the engines surveyed and the said the leak was coming from the covers so I’ll try to tighten first
88 32’ Fisherman
“Get Busy Livin”
Twin 360’s
Postby Fastjeff » Tue Nov 13, 2018 7:03 am
Don't go nuts tightening those bolts! A quarter turn or less only or you can distort the metal cover.
Note that cork gaskets tend to crack over time and create a leak path.
Studini
Postby Studini » Sun Feb 10, 2019 6:43 pm
So what's everyone's thoughts on Blue Devil Oil Stop leak? Thinking about trying it for the valve cover leak??
88 32’ Fisherman
“Get Busy Livin”
Twin 360’s
Postby javalin390 » Sun Feb 10, 2019 7:06 pm
Never been a big fan of all of the wacky additives that are supposed to solve every engine ailment under the sun. Personally, as a professional mechanic, I never use them. I'd much rather fix the problem, as I've have seen many of these additives either 1) not fix the problem at all, 2)make it worse or 3)cause a new second problem. I have seen some additives actually cause internal engine damage. The engines in mine (she has Chrysler 360's) use the rubber/steel backed type and they do not leak if properly installed. https://www.summitracing.com/compare
Studini
Postby Studini » Sun Feb 10, 2019 7:37 pm
Yea I'm probably going to do it the "right" way but those exhaust manifolds scare me and it looks like it can be a big project..
Motorhead your link did not work. Can you share again??
88 32’ Fisherman
“Get Busy Livin”
Twin 360’s
Postby jralbert » Sun Feb 10, 2019 9:01 pm
All the intelligent articles I've seen over the years downplay the effectiveness of those additives for the reason the other poster just put up. Their main benefit is to the company that makes them. People buy them because they promise an easy way out.
