Starting challenges
Leviathon
Starting challenges
Postby Leviathon » Mon Jul 02, 2018 11:57 am
Starts with the screwdriver trick, but not the ignition switch - just a click. Oh, starter/solenoid are an hour old.
S
Steve and Mary Levi
1973 32' Marinette Fisherman
Twin Chrysler 360's
El Ohssa
St. Joseph, Michigan
hightension
Re: Starting challenges
Postby hightension » Mon Jul 02, 2018 3:18 pm
Is it grounded good
Rodney Hack
Louisville,Ky
Leviathon
Postby Leviathon » Mon Jul 02, 2018 8:55 pm
Well, figured it out. 45 years was enough for the wire that goes from the "I" on the ignition switch to the "S" on the starter. After replacing the starter, ignition switch, battery cables, moving the ground 100 times, I finally ran a new wire from the ignition switch on the bridge to the starter and that was the ticket. Would start about 30-40 percent of the time, otherwise just a click. Fun!!!!!!
Steve and Mary Levi
Twin Chrysler 360's
El Ohssa
Postby jralbert » Mon Jul 02, 2018 9:15 pm
Excellent info for others facing same problem. I recall Jeff Perry once writing here years ago -- look for the simple stuff first. Actually this wasn't "simple" - rather a case of apparently hidden bad wire
Postby Fastjeff » Tue Jul 03, 2018 7:07 am
And I never found the SOB that caused Mr. Port to do that crap now and then, usually after the boat sat a week or so.
Changed EVERYTHING in sight, doubled up in the wires coming from the ignition switch, changed the ignition switch, even added relays at the starter to eliminate any possibility of low voltage. And.... No luck.
So...I'm not the one to ask for help here.
