Running light bulbs
Trowerpower
Re: Running light bulbs
Postby Trowerpower » Sun Jan 14, 2018 8:54 am
Thanks for your replies!
Trower Power
Blue Sky
Performance Distributors
750 Edlebrocks
fresh water cooled
1.5 to 1 velva-drives
Onan 6.5kw gen set
Postby bcassedy » Wed Jan 24, 2018 9:05 am
Bought some led replacement bulbs to try as replacement to incandescents in instruments. Work great! Takes a little pressure to get them into sockets but they do work fine. Only caveat.... appears the instrument maker put a orangeish rubber "hood" over the regular bulb to dim them a bit. The instrument's display seems to be more "defined" which I like. The leds don't appear to project too much light when facing the instrument. Looking at the instrument from behind... the whole body of the instrument "glows". Since there's little heat from these, I don't think (to be determined) it'll be a problem. The rubber "hood" will fit over the new led's if needed. Plan on also replacing the upper station's (and lower station's overhead console's) backlight's with same type.
https://www.ebay.com/itm/10pcs-12v-Dc-1 ... 2749.l2649
'88 32' Sedan Bridge
Twin 318cu in Chrysler
1.5:1 Velvet drive trannies
Fresh water only
jennis9
Postby jennis9 » Wed Jun 06, 2018 10:45 pm
When you upgraded to led for the anchor, port and starboard did you have to replace the fixtures or is there a conversion for using the old fixture?
FINALLY GOT IT!
1986 Marinette Express 32
w/twin Chrysler 318s
Located on Lake Erie
FCYC, Cleveland, OH
Postby TinLizzy » Thu Jun 07, 2018 12:36 am
You can usually get by with changing just the bulb out to led, or the whole fixture if you felt like it.
Postby jralbert » Thu Jun 07, 2018 2:07 pm
jennis9 wrote:When you upgraded to led for the anchor, port and starboard did you have to replace the fixtures or is there a conversion for using the old fixture?
Modern LED's fit a variety of sockets. They have standard designation and you just have to make sure you know what socket you have -- the fixture mfr can tell you if it isn't otherwise clear. Changing the fixture isn't necessary. LED's are a vast improvement over the 12v incandescent bulbs mainly in their lower current draw and longer life span.
jennis9
Postby jennis9 » Thu Jun 07, 2018 8:54 pm
Thank you! I'm going to make that happen!
FINALLY GOT IT!
FCYC, Cleveland, OH
roland89
Postby roland89 » Fri Jun 08, 2018 9:47 am
I always buy replacement bulb from Five Oceans
https://www.five-oceans.com/collections ... -led-bulbs
They have a 30% OFF now, promo code NEWEB
