Hello Everyone,
I am a long time reader of this site and first time poster. I am in the middle of restoring my 1977 32' Sedan. Projects include new paint job, repower, interior remodel, and hydraulic upgrade. I am on the final steps of the paint job, need to spray two coats of topcoat. I want to thank everyone for the vast amount of information that I have taken of this site throughout my project.
Now on to my question. My fuel sender isn't working and I would like to replace it with a reed switch sender. I am told that the mounting pattern is odd and that it is a hard part to find. I am going to try and attached the picture I have. Assuming I can upload the picture, does anyone know where I could purchase a new sender with this bolt pattern? If not what option should I explore to address this? Weld a patch on the fuel tank and install a new sender?
Thank you in advance,
Steve
http://www.marinetteboat.com/forum/down ... iew&id=870
Square Mount Fuel Sending Unit
- Attachments
- IMG_0164.jpg (33.75 KiB) Viewed 16651 times
1977 32’ Sedan with Flybridge. Twin screw Chrysler 318. Home Port: Michigan City, IN
Re: Fuel Gauge
I matched mine up at West Marine. Of course, that was a duplicate of the original gage.
PS: I adjusted both gages so that 15 to 20 gallons of fuel were left when the needle it hit "E". Reassuring when you can't find a gas station open!
- tundrarules
Re: Fuel Gauge
Steven,
Welcome to the forum. Forum etiquette says that you should start a new thread of your own. Hijacking someone else’s subject is a no-no. No harm, no foul. I think I did a few times myself long ago. Just helping you out. Welcome and good luck on your project. Can’t wait to see your restore.
Admin started a new thread
1985 29 Sedan
Edelbrock 1409 carbs
Mallory distributors
780 hrs/eng
TN River, MM 213.8
780 hrs/eng
TN River, MM 213.8
Re: Fuel Gauge
Thanks Jeff. I will remove and take it to West Marine. Sorry about hijacking this post. I will start a new going forward.
Re: Square Mount Fuel Sending Unit
Steven,
You may be able to have (or make) an adaptor from a thick piece of aluminum.
Like this maybe?
Like this maybe?
Big
's Rule !!!
Big
Thanks Metalhead. I Will explore this option also. I decided to work on the engines/fuel tank next instead of spraying the last two coats of topcoat. I figured it would be easier to repair the paint if damaged during engine removal at this stage.
