Haul Out Schedule
Haul Out Schedule
Re: Haul Out Schedule
Marysville Marine is were I got my non metallic cutless bearings. You just have to know the exact sizes. There is also cutless bearings in the rudder tubes, usually you have to cut the bearings in half and put one in the top side and one in the bottom.
Carl,
Full length bearings aren't needed. The supporting points are more than adequate. Additionally, when it comes time to change them (in several years), you'd find it very tuff to remove.
NOTE - FastJeff had a process on an old site that used a reverse ground "V" chisel to remove old bearings.
I purchased my non-metallic bearings from this place:
https://www.deepblueyachtsupply.com/marine-bearings
Worked out great!
Worked out great!
Maestro
1986 32' Sedan
Chrysler 360s
1.5:1 Gears, 16x16 props
1970 28' Express
Single Chrysler 440
1:1 Gear, 14x12 prop
Green Bay, WI
1986 32' Sedan
Chrysler 360s
1970 28' Express
Single Chrysler 440
Green Bay, WI
After reading that list, boy am I glad to be a trailered, 19 foot I/O guy!
