No small leaks
No small leaks
I had a small leak in the pipe feeding the toilet valve. This caused the front bilge pump to activate periodically so I turned off the city water when I left the boat. Then I noticed that the front bilge pump was running a lot more often even with the city water turned off. The inlet port had busted off the air conditioner water pump and lake water was flooding in. I had installed a new battery charger and it was keeping up with the flow. In this case the small leak was masking a potential boat sinker. All leaks are bad -- Fix em.
Re: No small leaks
Note to all: The city water valve should NEVER be left on when leaving the boat! More boats swamped from doing that than you would believe (see Boat U S Insurance write ups). We lost one at our slip a few years ago for that reason--a pipe burst and down she went.
Re: No small leaks
Yeah never ever leave the city water on. I have a shut off on the hose where it attaches to the boat as well. Jeff is right more boats sink at the dock than anywhere else last time I heard.
Inland C's
ZF Trannys
Port Clinton, OH
1972 32' Marinette FB Express
Siff Surf
Twin Chrysler 318s
Port Clinton, OH
Inland C's
ZF Trannys
Port Clinton, OH
Siff Surf
Twin Chrysler 318s
Port Clinton, OH
Re: No small leaks
I never hook up the city water hose. Just fill the tank.
Roger
Roger
Roger Brown
Petersburg, IL
Roger Brown
Petersburg, IL
