ATF 89 28 ft express
Port Transmission has a small fluid leak . But it's time for this seasons fluid change. What ATF do you suggest. I have 1,200 plus hours on the engines.
Thanks Steve
Recommended fluids
Recommended fluids
steveintn
1989 28ft Hardtop Express
T318's
Tennessee River - Ft Loudon Lake
Lenoir City, TN (Knoxville)
T318's
Re: Recommended fluids
Check transmission manual. I doubt it's ATF, My Twin Disk use 40 weight or diesel engine oil.
Roger
Roger
Roger Brown
Petersburg, IL
Roger Brown
Petersburg, IL
thanks for the reply.
its a velvet drive. i know its a ATF. I was just wondering if a specific type would help with a leaking issue. A high mileage or something. i know cars have a fix a leak. i have not considered or tried anything like this. A buddy of mine has a car repair shop - he is a fan of the Lucas products.
steve
steve
steveintn
T318's
T318's
Velvet Drive Use any of the Dextron I , II, II etc ATF
I change tran fluid every 50 hrs. I pump out the dip stick hole. I do not drop the cooler. Changing every 50 hrs will keep recyle it through without dropping and draining lines. IMHO additives for leaks are a poor band aid fix if any. They can cause more problems to these reverse gears than any small leak!
- tundrarules
Dave is correct (of course). Dextron III is what manual calls for. Uses see as my Toyota Tundra..
Convenient for me buying the same fluids
I would not put additives in.. A small leak is no problem.. Just Ck your fluid and put a soak pad under it
1985 29 Sedan
Edelbrock 1409 carbs
Mallory distributors
780 hrs/eng
TN River, MM 213.8
780 hrs/eng
TN River, MM 213.8
dextron iii
should I use a "high mileage" style or just a regular major brand like castrol
steveintn
T318's
T318's
